Ford F250 V10
roostershooter
I am considering a Rockwood fifth wheel with a dry weight of 6592, a dry hitch weight of 1181, and a cargo capacity of 1458. The GVWR of the pickup is 8800. The f250 has 3.73 gears. This truck will probably pull the fifth wheel ok but will it struggle in hills/mountains? Any insight is welcome!
22 REPLIES 22
mosseater
As I looked at your numbers, I couldn't help but notice you're very close to what I'm pulling, even though mines a TT (which should make me even worse?). I'm not putting out the torque numbers you are and I do fine. No, you won't be winning the towing races, but you'll get it done. I would think payload should be in the 2600 lb range for your 250.
"It`s not important that you know all the answers, it`s only important to know where to get all the answers" Arone Kleamyck
"...An unarmed man can only flee from evil, and evil is not overcome by fleeing from it." Col. Jeff Cooper
Sunset Creek 298 BH
roostershooter
My concern was. the rear end ratio as well. I did not want to get into a situation where the truck was such a dog that I would be forced into a different tow vehicle. It has been a strong runner and a solid performer so far. Thanks everyone.
ReneeG
I would agree with those here that said you'll be ok. We used to have a '99 F250 V10 but we had the 4.3 gear ratio and we towed everything from a 25' TT, 29' TT, 32' TT, and it did fine, with plenty of power to tow these, and that's with the 32" TT being close to 10K. When we upgraded to a 35' fifth wheel with a GVWR of 14K, although we never towed to full capacity, the truck struggled, really struggled. Our mpg was 7 - 9. Since then we have upgraded to an F350 DRW Diesel and all is well again.
2011 Bighorn 3055RL, 2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3, 1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica, Mabel, and Melton
rowekmr
I towed my TT through the hills of TN with no problem but I did have 4.30 gears. Can't see why yours will have any problems much less struggle as long as you don't mind hearing the engine rev. The V10 has to spin to make power.
10 Lincoln MKS Ecoboost
07 Lincoln Navigator
00 Newmar Dutch Star 3851
roostershooter
2001 pickup. The fifth wheel is 2014. I do not know the payload of the truck. It is just an extended cab pickup. The model of the rockwood is the 8244 lite series. I bought the truck new. The length of the camper is 26 feet 9 inches.
fla-gypsy
With an 8800 GVWR that would be a pre 2005 model. It will have the 2v version making 310 HP and 420 ft lbs torque and If all the maintenance has been kept up it should do just fine. The 3.73 is not the greatest towing gear but should be adequate and payload will be in the 2500 lb range so no problems there
lawrosa
Wow open question... What year is the 250 v 10?
Your looking 8K trailer and 8.8 k pick up???...
a dry hitch weight of 1181 but whats the payload of the truck????
Sure it will pull it maybe IMO,,, But youll be white knuckles.. We need to know more info....
More info period.............. Cant make any recommendation without it...
1. Truck year
2. TT model and year?
Thats a minimum....
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
brirene
I'm not sure you can describe it as "struggle". You won't be the fastest one up the mountain, and you'll have to let it rev pretty high, but you should do ok. That seems pretty well matched, imo. Expect mileage in the 6's though.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
