Feb-11-2020 07:00 PM
Feb-12-2020 03:57 PM
Feb-12-2020 01:18 PM
opnspaces wrote:
I think most if not all RV tanks are just a single wall tank. The fact that you are finding a hose makes it seem that the valve is mounted remotely from the tank. On my trailer the valve is mounted under the side where it is easily accessible. There is a tube behind the valve that disappears back through the corrugated plastic underbody and then over to the actual tank. Since it sounds like you cannot see the actual tank I would start figuring out how to get the underbody down so you can see what you are dealing with.
Feb-12-2020 01:17 PM
Feb-12-2020 01:06 PM
Feb-12-2020 12:54 PM
opnspaces wrote:ER Alaska wrote:
The problem is that when I pull on the valve I can see just a small amount of the tubing (the tubing is cut at an angle a bit, so I can just see a little part of the end of the tubing) and when I try to pull on the valve the end of the tubing gets hung up on the tank opening. If I could get the tubing through the opening I could then clamp onto it. Main question/uncertainty is what would be the consequences of having the tubing separate from the valve and the tubing stay in the tank. Thanks.
I would examine very carefully as the tubing makes no sense on a single wall tank. When you pulled the valve off the tank did water come out? My thought is that the tubing goes back into an inner tank of sorts, and the part that holds the actual valve is not water tight. Maybe try adding a tiny bit of water with the valve loose and see if it only comes out the tube.
Feb-12-2020 06:28 AM
Feb-12-2020 05:47 AM
Feb-12-2020 04:18 AM
Feb-12-2020 04:04 AM
Feb-11-2020 11:46 PM
Feb-11-2020 07:07 PM
