furrion 50 amp cover
cleojayco
the 50 amp cover for the power plug has broke off can the cover be replaced
11 REPLIES 11
cleojayco
sounds easy enough thanks I think I'll try it
GrandpaKip
cleojayco wrote:
Is it that tough to re wire a new plug? or take it in for replacement? thanks for the input
Usually 4 screws and caulk/butyl tape. Pull out and take the 4 wires off. Put the 4 wires the same way on the new receptacle and reinstall.
Should be just as easy as it sounds.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Lynnmor
If this simple task is difficult for you, RVing will sure be a chore.
cleojayco
CavemanCharlie
Where did it break ? By just looking at the pictures if the hinge pin broke maybe you could drill all the way through it and use a small bolt as a new hinge pin.
deltabravo
deltabravo wrote:
cleojayco wrote:
does anyone know how difficult it is to replace the plug
It's probably held in with screws.
SAME HERE
2009 Silverado 3500HD Dually, D/A, CCLB 4x4 (bought new 8/30/09)
2018 Arctic Fox 992 with an Onan 2500i "quiet" model generator
deltabravo
This one, the screws are visible behind the cover.
deltabravo
cleojayco
SidecarFlip
Probably not. You'll have to buy the entire plug from Furrion.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
drsteve
Maybe.
https://www.ebay.com/bhp/rv-electrical-hatch
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
