FW capacity
Gjac
I just started looking on line at TC's and noticed there are not many units that have more than 30 gals of FW. Those of you that dry camp most of the time which I assume most of you do where do you store extra water?
63 REPLIES 63
Gjac
These have been very informative posts for me having never camped in a TC or even owned a truck. My thinking for a TC was that I could always use a truck as a second vehicle. I also noticed most of you have DRW trucks. Did purchasing this kind of truck for other uses factor into your decision for the truck and a larger camper? If you did not require a DRW for other uses at home or farm use would you have purchased a SRW truck and a lighter camper? I have been driving for over 50 years without one so my only reason would be to haul a TC and maybe some firewood.
Bedlam
Moderator
Moderator
I came to the truck camper world from the toy hauler side and was spoiled with a 10 gallon hot water heater, dual 75 gallon fresh tanks and dual 50 gallon waste tanks, so even there it was easy to over fill your waste unless you managed what went outside or carried a tote for overflow. It was an adjustment for us, so we chose the truck campers that had greatest capacities and compensated with additional tanks in our enclosed trailer. I remember looking at the Northern Lite 8-11 and really loving the quality, but was put off by the small 30+ gallon fresh tank and waste tanks so small the combined capacity was less than just the gray on other campers.
I would guess only 1/3 of the nights we camp are without hookups. Of those boon docking nights only about a week per year are we in a location where we can use the external shower to divert gray water. We currently comfortably boon dock for three nights without worrying about usage - Next month we are going to try to double our boon docking with only onboard tanks and see how long we can go.
burningman
The water in the heater gets used if you take showers or anything else using warm water.
My camper goes to Burning Man (hence my username) where absolutely zero grey water, trash, or anything goes on the ground.
Sometimes it goes to races or car shows where you canโ€™t dump anything in the ground.
Itโ€™s going to the Bonneville Salt Flats where you canโ€™t dump on the ground. In fact you have to park on a tarp so you donโ€™t so much as leak a drop of oil.
Sometimes itโ€™s even a portable guest house for visiting friends
Iโ€™m a little surprised Iโ€™m that much the odd truck camper user. I almost never go to a campground.
My primary reason for owning it is the heavy trailer pulling ability.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
Gjac
kaydeejay wrote:
Gjac wrote:
sbryan@vtbryans.com wrote:
We have a Northstar Igloo and we have 40 gallons of fresh water. What really makes that work for us is the cassette toilet, which has its own 5 gallon water supply and that can be used with very little water. We also carry jugs for drinking water and mostly use the FW thank for showers and dish washing. It's amazing how little water you can get along with if you try.
I just looked at your model online, looks nice with a dry weight of 2600 lbs, I am guessing that the traveling weight would be less than 3600 lbs, does that mean a truck with 4000 payload would be sufficient to haul it? Also I notice that the new Ford F150 with the 3.5 eng has a payload of 3700 lbs would this be sufficient?
What about people and "stuff" in the truck? They use payload too.
Right, if a camper weights 2600 lbs dry then water, food, clothes people and other stuff can't add up to more than 1000 lbs, at least that is how I understand it.
Kayteg1
zcookiemonstar wrote:
Not sure why people count the water heater tank as fresh water capacity. Once your fresh water tank is empty other then the drain plug how can you use the water in the heaters tank?
Well.. that is valid option to dying from thirst.
zcookiemonstar
wnjj
Fresh water ends up in the black tank too. Iโ€™m happy to have a larger fresh tank than both gray and black. The fresh runs out long before the others are full.
Many campgrounds have a gray water disposal for tent campersโ€™ dishwater.
Kayteg1
From what I know taking outside showers is allowed everywhere.
Only on few campgrounds with faucets at driveways I have seen signs "no dish-washing"
burningman
You guys are assuming everyone uses their truck camper to go into the woods.
Where I usually use mine, dumping the waste water on the ground isnโ€™t an option.
work2much
burningman wrote:
Remember to pay attention to the waste tank size too.
All my previous campers were way outta whack on that.
My last two had 40 gallons fresh, and about 15 or so grey. Less than 20.
That made half the fresh water useless.
Iโ€™m really liking my current rig, it has more waste tank capacity than fresh. I can use all my water now. You want to make sure you buy something like that, what comes out of the faucet has to be able to go down the drain.
Unless you go shower outside. ๐Ÿ™‚ Plus pee outside. Plus loading up water bottles for hiking and biking that never gets into holding tanks.
From what I have gathered boondocking in remote places it really is the amount of water and wine you bring. All else can be mitigated.
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
Grit_dog
Navigator
Navigator
Just camp where if ya leak a little gray water out, no one notices......
Don't go water the lawn like cousin Eddy, but if you're in the woods, not a big deal.
burningman
Bedlam
Moderator
Moderator
My short bed Arctic Fox 811 had over 40 gallons and my Host Mammoth has over 60 gallons. I also carry an 84 gallons in my enclosed trailer and 30 gallon gray tote for overflow. Usually we will use the outside shower if boon docking like this to keep from filling the gray too quickly.
kaydeejay
Keith J.
Sold the fiver and looking for a DP, but not in any hurry right now.
Gjac
An F150 has a 3700lb payload?
According to Fords web site a regular truck cab is 3270 lbs. I was going by memory which is not too good. That still seems like a lot for a 1/2 ton truck.
