Gaining jack clearance when camping
billyray50
After reading all the posts in "Drop your camper at the campground". I suddenly realized that I have to use 3 1/2 solid cinder blocks and 1/2 inch plastic jacks pads to gain enough height to unload/load my 1998 Lance 990 legend for clearance. My 2006 Dodge sits higher now with extra leaf spring in each rear pack, airbags, 3rd generation higher Dodge bed rails, and taller Nitto Durra high load index tires. What could I use at campgrounds or anywhere for that matter that is lightweight? Do not want to haul 4 solid cinder blocks around for sure.
5 REPLIES 5
dadwolf2
Sorry, when I looked at your profile I thought you still had the Adventurer with Happijac's and missed the Lance.
2005 Dodge Ram 2500 CTD,4X4,NV5600
2014 Adventurer 86FB
AnEv942
Atwood does make extenders, as do other mfgs-refer to couple of older threads.
http://www.rv,net/forum/index.cfm/fuseaction/thread/tid/26593156.cfm
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26667400.cfm
Not sure but I think Id lean toward making similar to the bolt on for Happijacks. mentioned here
http://www.rv.net/forums/index.cfm/fuseaction/thread/tid/25554684.cfm'Seems' might be a bit less likely to wobble, trying to drill some holes in the foot doesn't sound like fun though. Hopefully those who actually use/used either will chime in.
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
K_Mac
I carry 4 pieces of 6 x 6 with me when I know i'll be taking TC off. I have Cedar 6 x 6 and they weigh about a quarter of what a PT 6 x 6 weighs. Billyray , my 98 Lance Squire had the access doors by the wheel wells and that's where I carried them. I'm sure your's in similar. K
billyray50
I have electric Atwood Jacks. Not familiar with them. Just tried a search.
dadwolf2
You can get 6" jack extensions. That's what I carry with me.
