You'll need to flush and clean your fresh water tank and replace the faucet. Go to your local Home Depot and get yourself a new faucet. A regular bathroom faucet will fit and install is simple. Check their discontinued faucet displays first..you might have to ask. Remember teflon tape....Dennis
How to sanitize your fresh water tank:
1. Make sure your water heater is OFF and cool.
2. Determine the capacity of the fresh water tank.
3. Mix 2 ounces, max, household bleach for every 15 gallons of water to put into your tank. I use a 5 gallon water bottle and mix about 1/2 ounce bleach with it. Be sure to mix the bleach with the water before pouring it into the fresh water tank. This is important.
4. Make sure you're not hooked up to an external water source..use the RV pump.
5. Open up one faucet at a time, allowing the chlorinated water to flow through the faucet for one minute.
6. Close all faucets and top off the fresh water tank. Let sit for a couple hours or overnight if you prefer.
7. Now you want to flush your tank. Open the tank drain or if you don't have one, open all your faucets and completely drain your fresh water tank. Don't forget to drain the water heater as well.
8. Fill the tank with fresh water and repeat step 7 above.
9. Fill the tank again and the water should be safe to drink. If you still smell chlorine, you can flush the tank a third time.
I know this sounds like a lot of work, but it's a simple process and one that will keep you healthy. Remember too, not to let your fresh water tank sit that long in the future. Good luck...Dennis
We can do more than we think we can, but most do less than we think we doDennis and Debi Fourteen Years Full Timing
