Generator exhaust bracket.
Pete_k
Our 2016 Eagle Cap 1200. Had a banging sound when running the Generator. Found the rubber isolator exhaust bracket had broken. Looking online the replacement was $65. Being I will not pay that for a cheap part. Found a replacement for only $4.97
Used this mount.
Click For Full-Size Image.
Used the factory screws and top mounting holes. Worked perfect to mount this one back into its spot.
Then I loosened the clamp on the pipe itself. Twisted the rubber and bottom mount. Slid it up under the pipe clamp. Tightened that clamp back down. Job was done in under 5 minutes.
[img] Click For Full-Size Image.[/img]
2022 Ram Big Horn DRW
2016 Eagle Cap 1200
2012 Landmark Key Largo
2005 Chevy Kodiak c5500 Cummins 5.9/Allison Trans
6 REPLIES 6
mleekamp
That's the way to do it...65 bucks is a joke. Some will get fooled, unfortunately.
Pete_k
bgum wrote:
18 wheeler tire treads are good to isolate vibration. I generally have one available for projects and they are free.
I have also used old conveyor belting. But was not worth the time and effort. Being the part was less than $5. at the parts place.
2016 Eagle Cap 1200
bgum
jimh406
Thanks for the reminder. I need to replace mine as well.
Lwiddis
$65....lol. Not me either.
gitpicker2009
Thanks! I was just starting to work on that same problem. They're at O'Reilly's auto parts for 6 bucks.
