Getting under belly enclosed and slide topper.
Camper76
Looks like we are deciding on the Jayco jay flight SLX. One dealer will enclosed the belly and will put a slide topper on. Will enclosing the belly make a different towing? We just camp during the summer months. Should we get a slide topper installed? How do people like them?
Thank you
Happy Camping
5 REPLIES 5
valhalla360
Nomad III
Nomad III
Enclosing the underbelly is not about towing. It is to insulate the underbelly (to a degree). A bigger issue with winter camping where it helps stop the tanks from freezing but even in summer it will help a bit.
We like the slide toppers as it keeps rain and debris off the top. If you camp in the woods without a topper, you have to sweep the branches and leaves off before pulling the slide in. With the slide topper, you generally don't have to do anything. Plus it helps with cooling as the top of the slide is shaded.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Camper76
ScottG wrote:
Find out what topper the dealer is installing and check the model number on-line. It's probably fine but some factorys, like Northwood, buy a sub-par CareFree unit that is only available to them. It's such a POS that it's not worth having.
What company is good?
ScottG
coolmom42
I wouldn't pay for enclosing the belly, but the slide topper is worth having.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
SoundGuy
Zero. Don't waste your $$. ๐Ÿ˜ž
2012 Silverado 1500 Crew Cab
