โFeb-19-2014 04:34 AM
โMar-03-2014 12:20 PM
maxwell11 wrote:
gm will be making their trucks with AL bodies following ford to get the weight down for fuel mpg goals I guess.
Will cut the weight, but wonder how it will hold up in the real world, salt, road grime, etc: over the years.
Wonder if the engineering dept has any old school logs left from back in the day:
Do you remember GM trucks back in 1973-1975, they changed something in body protection and some bed fender wells and cab corners were rusting out in 6 months.
โMar-03-2014 05:24 AM
โMar-03-2014 01:27 AM
FishOnOne wrote:
I'm not sure I agree with all this... Ever compare the weight and strength of titanium to Stainless steel.
In addition removing weight from a vehicle will improve highway fuel economy. Try a highway fuel economy test with your current truck with and without 1k pounds in the bed of the truck.
โMar-03-2014 12:39 AM
Passin Thru wrote:
YOu can't buff the tailgate, CA will give you a ticket for blinding someone following you. Stupid law but that's why they have quilted aluminum doors on Great Dane Trailers.
Wes Tausend, Why do they use Titanium on airplanes if it isn't stronger and lighter than steel? I sure broke a lot of drill bits adn screwdriver bits on titanium. Also, I read an arcticle thant said Carbon Fiber was corrosive to any metal it touched due to dissimilar metal corrosion. The use of carbon-fiber composites with steel structures requires a thorough understanding of the phenomenon of galvanic corrosion. In theory, as long as two materials have not
contacted each other, a corrosion cell will not initiate. However,
in case of direct contact between carbon fibers and steel
in the presence of an electrolyte, the wet corrosion cell could
accelerate the corrosion of steel and create possible blistering
and subsequent delamination or debonding.
Probably why they don't use carbon fiber in vehicles that run down roads we salt and use calcium chloride on.
...................................Material.....................Density...........Specific Strength
.....................................Strength.................(g/cmยณ)...............(kNยทm/kg)
......................................(MPa)
Magnesium........................275_________1.74____________158
Aluminium.........................600__________2.80____________214
Stainless steel.................2000_________7.86____________254
Titanium...........................1300_________4.51____________288
Bainite.............................2500_________7.87____________321
Balsa (axial load)...............73__________0.14____________521
Scifer steel wire.............5500__________7.87____________706
carbon-epoxy compo.....1240_________1.58____________785
spider silk......................1400__________1.31___________1069
Silicon carbide fiber.....3440__________3.16___________1088
Glass fiber....................3400___________2.60___________1307
1 ?m iron whiskers......14000__________7.87___________1800
Carbon fiber (AS4).......4300__________1.75____________2457
Kevlar.............................3620__________1.44____________2514
Carbon nanotube.........62000_________.037-1.34________46268
Colossal carbon tube.....6900___________.116__________59483
โMar-02-2014 06:32 PM
Wes Tausend wrote:
There are some misunderstandings when it comes to aluminum.
For equal strength, equal weight is required. One material is not stronger per pound than another. Sort of. Advantages do depend on how one, or the other, is used.
Aluminum works best for panels, hulls and aircraft skin because it is less dense and sheets are thicker. Just like some noted, the extra thickness is resistant to flex. Most of the coming vehicular advantages rely strictly on this principle. The thinner and thinner high carbon steel panels now used on body panels are about at their "thin" limit. It is unlikely that the entire body (ala Jaguar) or automotive frame will ever be aluminumm because of rapidly diminishing returns on investment. Too expensive, too exotic. Offhand, someone mentioned using aluminum on 3/4 tons. This was already done on my 2000 Excursion 14 years ago; the rear hatch doors are aluminum.
The reduced weight will not improve highway mileage much at all. Reducing extra weight on highway travel only decreases rolling resistance by a negligible amount. Once something is rolling, wind is the enemy. Sure, uphills are harder, but following downhills recover much of the used energy; unless one must brake. But light weight will improve stop & go city mileage, thereby raising combined economy to meet new standards. That is the plan.
The repair of aluminum is slightly different, but a rather simple process. My guess is that Ford will supply white sheet information materials to any receptive body shops, maybe even hold low cost "coffee/donut" Rep seminars at nearby dealers. $10k sounds way out of line, maybe the cost of an entire sales region.
Autobody craft organizations are already on top of this. There should be very little welding on aluminum. The only differences are using adhesives and/or rivits, plus the correct etching and primers. Most body shops already use adhesives on steel rather than weld, and are familiar with new coating/gluing products. Expect body shop suppliers to jump into the new market with their own enthu$iastic training. After all, brittle high-carbon steel panels are already R&R'd (remove & replace) rather than hammered out. The new thin steels are almost spring steel temper and don't work-form well anyway. This transition should be a piece of cake, easier than learning fiberglass, clear-coat systems and plastic interior trim/urethane bumper repairs.
Wes
โMar-02-2014 06:18 PM
โMar-02-2014 02:53 PM
Perrysburg Dodgeboy wrote:
Tne insurance industry is not going to eat the cost so the only way to keep rates the same as the current trucks ks if the repair cost are the same right?
Don
โFeb-26-2014 09:32 AM
โFeb-26-2014 07:13 AM
โFeb-26-2014 12:39 AM
โFeb-24-2014 03:28 PM
โFeb-24-2014 08:03 AM
โFeb-24-2014 07:34 AM
โFeb-23-2014 05:00 AM
Sorry but that 10G is what Ford is willing to pony up for some of their dealerships the cost is more then 10G. Sounds like a vocational school would be cheaper for non dealers.
Still going to cost more to insure.
Don
