Grooves cut in dual cam setup
NCMODELA
Hi, I installed the new dual cam and a round bar setup today, took it for a spin and there were fresh grooves cut into the cam on the dual cam, I figure this is okay because the two pieces are mating to each other and they are metal on metal (Should it be greased?) but just wanted to reassure myself it was normal.
Thanks
8 REPLIES 8
mooky_stinks
Marking them and eventually flipping them assures that your getting the full use out of them. Not marking them, you really never know if you're switching them equally from side to side.
2020 F150 XL Screw 4x4 6.5โ€box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
hilandfrog
I'm a dumb guy and don't even have any cams outside my engine.
That being said, IF one were to keep bars L and R till worn then switch and wear out other side... would not the same amount of wear occur if one randomly put the bars R or L...
Not a physicist nor metallurgist, but IF they are going to wear to a point then one flips them, wearing both sides would give the same term of service yes??
Repo
05 Tundra 4x4
1977' Road Ranger, Diddums is in action.
jerem0621
I agree with the advise above. Keep your WD bars left or right. They will wear in to their specific cam.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
NWKomfort350
I use vaseline with my dual cam... 1050 pound tongue weight 1200 pound trunnion bars..
Chris & Stephanie
2 kids - 1 boy / 1 girl
Winston (boxer)
2016 Open Range Roamer 367BHS
13 F350 6.7 CREW LONG BED SRW
B & W Patriot
02 F350 7.3 SC LB SRW - SOLD
2014 Keystone Cougar 281BHS - SOLD
dodge_guy
Yes normal. do not grease them, but if you are over 1200lbs tongue weight it is OK to use a dab of grease to eleviate the excessive wear! nothing to worry about. after awhile the wear will subside and will be nothing. after a few years you can flip the arms over and use the bottom side which will be a new surface.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
mbopp
I have a piece of tape wrapped around one bar designated as the right side. The bar & cam on each side are now worn in together.
2019 F250 XLT Supercab
Just DW & me......
ktmrfs
Gene&Ginny wrote:
Some grooving is normal. DO NOT grease the cams.
x2.
Reese says that you can use a very light coat of vaseline if needed to minimize noise. usually not needed on the lighter bars, but I do use it on my 1700lb bars since tongue weight is so high (1400lbs loaded with water)
2011 Keystone Outback 295RE
Gene_Ginny
Gene and DW Ginny
[purple] 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363[/purple]
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
