GVWR of a 2009 Dodge Ram 3500 Truck Quad Cab Laramie
ryoung
Hi all. I'm wanting to get back into TC after a 4 year hiatus. I saw the above truck listed the other day and was wondering what the payload would be for this SRW truck? Guessing the GVWR around 10K
but have no idea on the curb weight.
ryoung
I no longer own the rig in my signature, but wish I still did.
2018 Ram 3500 SRW Diesel
2019 Wolf Creek 840
6 REPLIES 6
3_tons
My 07, DRW, cummins, Quad cab, 4x4, LB, Laramie had GVWR of 12,200 per door jamb sticker, my 16 (same exact config) is rated at 14,000 GVWR...
3 tons
Grit_dog
Nomad III
Nomad III
Same axle and frame as your 04. 2 less rear tires and lighter springs.
If you're intending on going by the rated capacity on the door placard then skip it and get a dually. If you're only concerned with what the truck is capable of, then the axle is good for 10klbs. OE wheels are very conservatively rated at 3500-3600lbs ea and you can get tires up close to 4000lb rating.
Means a total cargo weight of about 4000lbs on the rear axle, with the right suspension for "stability" is good.
If it's a long bed, a shorter camper will likely transfer some to the front axle too.
Gvwr will be the most conservative if you're set on going by the mfgs numbers and you'll get hung up at around 2500lbs even though the truck isn't yet breaking a sweat.
romore
Can the seller give you the information from the door post sticker? You then have it for that particular truck.
donn0128
Should be 10,500 GVWR. My 07 dually scales 8000,and a GVWR of 11,500. so a SRW should be right around 7700 pounds ready to travel. SIL has an 07 SRW he put a Bigfoot on and he wishes he had a dually.
996Pilot
Go to the RAM BodyBuilder site. You can find all the weights for any year RAM
http://www.rambodybuilder.com/2009/docs/dr/mlup3500.pdf
2018 Arctic Fox 811
2015 RAM 3500 SRW Laramie Longhorn 6.7 Cummins 68RFE Timbren SES, Lower Stableloads
2006 Dodge Ram 2500 Laramie 5.9 Cummins 48RE TRADED
2006 Outfitter Apex 8 TRADED
Grit_dog
Nomad III
Nomad III
Idk, but it’ll haul a 4000lb camper just fine with a little suspension help
