HappiJac tiedown
Gary3
Would anyone be able to tell me if the HappiJac tiedown in my 2007 Dodge would fit the 2018 Dodge or would I have to buy a new one.
Gary  Lance  1191 solar Gen.
5 REPLIES 5
Gary3
It was a different part number mine was good till 2008 I ordered the truck today so I,ll wait till they call could be a couple mths then order the Torklift it sounds easier to install.
Joe417
I put 2002 Torklift's on our 2008 Chevy. I found 1 hole on each side had to be drilled.
Wouldn't hurt to fit it in place. If a single bracket is different you may be able to use a spacer to make it fit or Happijac may sell the one that fits your truck separate from the whole kit.
Joe and Evelyn
work2much
Not sure but I bet these folks would know.
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
BradW
This doesn't really help you, but the one I used on our 2001 F350 worked perfectly on our 2006 F350. I agree, checking the part numbers should help. You can also call Happijac and ask. I called them a few times and they were very nice and very helpful.
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
burningman
One way to figure that out is to look up the part number for yours and see if itโ€™s the same as whatโ€™s listed for the โ€˜18 application.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
