Happyjac 4500 overhaul
dack
I have disassembled the Jac and have a question regarding the position of washers on the internal screw assembly. The top of the screw assembly has a square 1/4 inch thick steel plate with dimple holes around the center. I think the holes should be on the downside. There is a thin washer also and I assume it should be on top of the plate. Happijac does not offer a equipment schematic. Anyone out there who can help me?? dave
5 REPLIES 5
stevenal
Nomad II
Nomad II
KKELLER14K wrote:
Blurry pics not sure why
Chrome killed the extension you suggested. Try the one I suggested above.
'18 Bigfoot 1500 Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
dack
I think I solved my problem. I found a nylon sleeve which was required to put it back together. Thx for looking
KKELLER14K
Tried to repost..still blurry...mmm.
KKELLER14K
stevenal
Nomad II
Nomad II
Perhaps this will help.
Use Chrome extension Photobucket Hotlink Fix.
