โMay-20-2018 07:16 PM
โMay-21-2018 04:16 AM
westend wrote:
Your Liberty is going to struggle, at times, pulling a hard sided trailer. Check your frontal area towing restrictions and keep the weight as low as possible.
โMay-20-2018 09:56 PM
westend wrote:
Your Liberty is going to struggle, at times, pulling a hard sided trailer. Check your frontal area towing restrictions and keep the weight as low as possible. I'd assume that you have an adequate transmission cooler. If not, install one before towing.
The added drag of a hard side trailer is something you may be not prepared for. I'd suggest to rent a trailer similar to the size you anticipate buying (can even be an enclosed cargo trailer) and experiment with a short trip.
โMay-20-2018 09:50 PM
โMay-20-2018 09:09 PM
SDcampowneroperator wrote:
You can go longer, more energy efficient and lighter if you avoid slide outs. Theres many a good 20-24' TTs within your criteria
Congratulations on your happy child. Every child is a blessing, even if its meant to be one.
โMay-20-2018 09:07 PM
โMay-20-2018 08:19 PM
โMay-20-2018 08:17 PM
โMay-20-2018 07:58 PM
โMay-20-2018 07:47 PM
โMay-20-2018 07:41 PM
โMay-20-2018 07:33 PM
