โJun-08-2013 04:39 AM
โJun-10-2013 07:47 PM
โJun-10-2013 07:13 PM
โJun-10-2013 07:09 PM
mhsmith wrote:tragusa3 wrote:
That was payload for the specific truck. Good advice to get it equipped how I need it. We do keep vehicles a long time and I have a tendency to go cheap and then regret it.
I went back and test drove an Eco today. Was a little disappointed that the transmission felt like it was trying to keep me out of the power. I hope that would change with tow mode and max towing rear end. Any comment on that? Also drove the 5.0 and felt the same. Got to say, Ecoboost didn't feel like the freight train many describe. I didn't sense the torque like I expected...maybe it doesn't present itself without a load.
Don't get me wrong, it pulled hard when floored, but I expected 2000rpm to be all I needed for rolling hills unloaded. It wasn't, I had to press on the peddle some.
Maybe I just don't have the experience to have an opinion.
The Ecooboost engine and trans need around 1000 miles before towing. I was headed down the road with trailer on first trip when sometime after the odometer rolled over 1200 miles it seemed to "wake up". I have read that they have the computer "lock out" max boost until it reaches a certain mileage. Others have noticed it sooner and some a little later.
โJun-10-2013 07:03 PM
โJun-10-2013 07:02 PM
โJun-10-2013 06:49 PM
tragusa3 wrote:I don't think the Transmission was trying to keep you out of the power. The motor makes max torque at 2500 rpms so it''s able to maintain speed while holding gears much longer. Also not sure what gears were in the truck that you test drove? That can make a huge difference too. The max tow pkg comes with 3.73's and 4.10's as a option. Towing my 33' 7500lb trailer I have never seen more than 2600 rpms on any hill with the cruise set between 60-65mph...
โJun-10-2013 06:06 PM
โJun-10-2013 05:46 PM
donn0128 wrote:My F150 Ecoboost averages 19 mpg on the highway, it makes 385hp and 430 lb/ft torque on premium fuel. Those are basically the same #'s as Fords 6.2L that will only average closer to 13mpg. We are only talking about a 5500lb trailer. The Ecoboost will pull that around all day in 6th gear at 1600 rpms and not even break a sweat.
OK lets do the math.
3/4 ton truck 100,000 miles=
1 brake job
1 set of tires,
1set of shocks
Zero tune ups
10 MPG going to work
1/2 ton truck
2 sets of P metric tires
2 brake jobs
1 set of shocks
Zero tune ups
Maybe 12 going to work
Hummm. I just don't see 12,000 dollars difference there? Maybe my math is off a bit, but the heavier duty truck will last longer all around because of the stronger components. Modern trucks if properly equipped will return fuel economy nearly identical . Remember to get the higher towing capacity you will still need the biggest motor in the 1/2 ton, same motor as used in the 3/4 ton. So where is this hugh fuel difference coming from?
โJun-10-2013 04:06 PM
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
โJun-10-2013 03:20 PM
โJun-10-2013 01:58 PM
tragusa3 wrote:
I was just pulling numbers out of my head. Your logic seems more correct.
You also make a good point that the 2014 getting the 23mpg on the highway is not what I should expect with a different rearend.
I've been doing lots of reading on the max payload option with the F150's. I spec'd out an Ecoboost with max trailering and max payload. Payload of 2620 like I have it. That is exactly the sweetspot I was looking for!
Sat in the F150 at the dealership and did genuinely like the truck better than the Chevy.
Now the kicker...I didn't mention that I qualify for the "A" plan with Ford. My mother in law put in 30 years in Detroit. With that plan and the current incentives, plus my trade, it brings the purchase right down into a comfortable spot.
I really like the idea of the torque being available without running up the rpm's. A little cautious of the more technical engine though. More reading.
Does any other manufacturer have a package that brings payload over 2500lbs in a half ton? I didn't see it.
โJun-10-2013 01:03 PM
โJun-10-2013 06:26 AM
tragusa3 wrote:
Really quality replies guys. Thanks so much. My wife and I have been sitting here with our morning coffee talking through all the variables, and it's enough to drive you crazy.
First, Donn, I figured the math this way (not all inclusive):
- 3/4 ton at an average of 11mpg (towing and not)= 100,000/11 = 9091 gallons @ $3.50 = $31,818
- 1/2 ton at an average of 17mpg (realistic with the new 2014 chevy) = 100,000/17= 5882 gallons @ $3.50 = $20,587
Difference of $11,231
As you mention, there are other expenses that favor the 3/4 ton, that should be considered.
To the option of buying used. I would jump all over a nice, used 3/4 ton. Problem is, everything I see listed with <30,000 miles is right up close to the new prices. Everything that saves significantly on price has more than 100,000 miles. So in order to free up enough in the budget to cover the extra fuel expense and the commuter car, I'd have a vehicle that I wouldn't trust all that much for 6,000 mile trips out west.
I completely understand and agree that too small a camper and not enough TV can both take the fun out of a trip. But budgets are budgets, and when you start looking at $40k to a truck and $20k to a trailer, it is just too large a price for us.
In the end, I've got a paid for half ton with 85,000 miles (that I trust) and a trailer that we owe another $5k on. We're enjoying local camping for next to nothing. Hard to stomach $8-1,000 a month in notes for conveniences.
Some of you may have noticed my thread on whether or not to buy a class C. That's another perspective to wrestle with. We see good examples that fit our needs for the same price as most of the pickup truck options. We then sell our current truck for a gas sipping commuter, sell our current trailer, and come cheaper on purchase prices.
I don't know...round and round in circles. Enough to drive you insane. In the meantime, we leave next weekend for a week camping on the beach with no notes to pay off. Hard to beat that no matter how hard the truck is working. ๐
โJun-09-2013 04:49 PM
