Hitch extensions
bristles
I know many of you pull a trailer behind the truck while the camper is loaded. My question is this. Would you still use the weight distribution hitch/sway bar set up with a hitch extension if the trailer normally needs a weight dist hitch. Seems to me it would not transfer the weight as intended. Any thoughts??
16 REPLIES 16
Vinsil
Buzzcut1 wrote:
yes and yes. Torklift even specifies that to achieve maximum tongue weight carry capacity on its extensions you must use one
This.
2017 Ford F-350, crewcab, 4x4, 6.7 diesel.
2016 Thunderjet Luxor 21' limited edition, Yamaha powered.
2016 Wolf Creek 840-SOLD, Arctic Fox 990 ordered.
Buzzcut1
Nomad II
Nomad II
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
