Hitch friction control
JCR-1
Where can you get new friction material..(brake shoes) thanks
6 REPLIES 6
jccjprince
etrailer.com has great service
RavensFan24
http://smile.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=friction+sway+bar
2010 Chevy Tahoe & 2015 Keystone Bullet Premier 30'
JCR-1
mbopp wrote:
Are you talking about a friction sway control, or trailer brake shoes?
A brake / clutch relining shop should be able to hook you up either way.
Thanks , but I was looking to replace just the friction material inside the friction sway control bar.. They are similar to a disc brake shoe. Does anyone know of any online supplier. No one around here has them..
jerem0621
Are you talking about a friction sway bar for the hitch or new brake pads doe the trailer brakes?
If your talking about a friction sway control...just go with a new one for about $30.00 at Harbor Freight....if brake shoes, go with the advice above....replace the entire assembly.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
mbopp
2019 F250 XLT Supercab
Just DW & me......
TucsonJim
Most any trailer supply house will have them. But most folks change out the whole backing plate brake assembly. It will usually include the backing plates, wire connectors, brake shoes and magnets for around $70-$80 per wheel. I just replaced all of mine for $72.00 per wheel from Camping World for Lippert forward adjusting brakes.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
