hitch or spray liner first?
xaugievike
in a perfect world, is it better to have a 5'er hitch installed before or after a spray-in liner?
If it matters - it would be for a BW companion hitch.
2015 Chevy Silverado 3500hd DRW.
Pulling Keystone Cougar 325SRX
A buddy and I started a blog - you can read it here:
http://twoguyscamping.blogspot.com
17 REPLIES 17
fj12ryder
I had Line-X installed after the center hole for the hitch was drilled. This was also a B&W Companion hitch.
Howard and Peggy
"Don't Panic"
donn0128
Install the hitch, then remove it do the bed liner. Then reinstall. That way the holes get sealed too
kaydeejay
My vote is for the liner spray AFTER the holes are cut but BEFORE the hitch is installed.
Cut edges get sealed that way.
Worked with my Superglide, but then I do not have rails bolted to the bed, my hitch sits on the pins mounted to the underbed brackets. My hitch does not touch the bed sheet metal.
Keith J.
Sold the fiver and looking for a DP, but not in any hurry right now.
