Holes in the Floor
bguy
During early and late season camping I have felt some cold air drafts on occasion. What I have found is that everywhere a pipe etc. passes through the floor, the area around it is left open. Is this cheaping out or does it serve a purpose? If I were to fill the holes, would you suggest expanding foam, batt or something else?
Thanks
Brian
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
9 REPLIES 9
nomad297
I would use Thumb Gum/Duxseal instead of spray foam. Spray foam can be real messy and may be more permanent than you would like. Duxseal is what we plumbers use for sealing all exterior penetrations to keep them weather and rodent-proof.
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
Bumpyroad
yes it is cheaping out, both on labor and materials. squirt some foam in.
bumpy
kmwaterboy
Yeah, steel wool followed with expanding foam is what I used.Some areas around the electric wires I just caulked,gap wasn,t very big and expanding foam can be messy.
WoodGlue
While a small margin between the pipe and floor is allowed for tolerances, anything bigger than a half a penny is cheaping out (poor construction)
WoodGlue
2002 Land Rover Discovery II
2014 Lance 1685 - Loaded - 4 Seasons - Solar - 2 AGM's
When Hell Freezes Over - I'll Camp There Too!
Lance Travel Trailer Info - Lance 1685 Travel Trailer - Lance 1575 Trailer
2oldman
Without knowing what kind of coach it is, I'd have to say cheaping out.
pianotuna
Nomad III
Nomad III
Hi,
I use curly kate pot scrubbers (stainless steel version) and then foam. If the rodents come after that they will find they have a sore mouth at the very first nibble.
Regards, Don
SWD
Probably stuff some steel wool in there too before applying the expanding foam. I have seen rodents develop a taste for that stuff.
Old-Biscuit
Cheaping out......
I'd get some escutcheons (cover plates....plastic/metal) from hardware store.
Cut a slit in them then fill area in floor with expanding foam and put cover around pipe and over hole.
colliehauler
Expanding foam, will also help keep out mice.
