PZebich wrote:
I have a 2kw Honda generator which is about six years old.
Up until a couple of years ago I always carried the Gen. in the
bed of the rig and when needed put it at the back of the trailer.
Got tired of moving the gen. I fabricated a carrier shelf attached
to modified bumper and strapped the gen. to it so wouldn't have to
move it,just pluged cable in and started it.
My problem is the generator vibrates a great deal and makes a
great deal of noise inside the trailer. So my question is has
anyone mounted a 2Kwatt Honda gen. to a mount on the back bumper
and if so did you have a lot of vibration noise? I wonder if my
gen.has a balance problem or is this normal?
"vibration" from your gen is completely normal and should be expected..
Strapping the gen to the back of your trailer now easily couples the vibration and noise directly to your trailers frame making it more noticeable.
While you could try a heavy rubber mat (like a 1/2" horse stall mat) I highly doubt you are going to eliminate 100% of the vibration..
Personally I would not be all the keen about having a portable gen mounted so close to my trailer.. Seems like a good chance of carbon monoxide poisoning (YES, I realize motorhomes have built in gens but they also are subject to gen exhaust getting into the RV).
A better solution is to keep your gen in the back of your truck and add a permanent "extension" cord from your shore cord up to your trailer tongue..
I did that with my TT and gen (120 lb 4Kw Chinese clone gen), my TT has a access door with the mouse hole, I put a 120V 30A RV socket (female end) inside the back wall of the cord storage.. Ran 10Ga wire up to the tongue and put a male plug on that end.
I plug the shore cord into the socket inside the access door when not on shore power.
Now all I do is plug in a short extension cord into the tongue plug and the other end into the gen socket..
Gen sits up at the front of my truck bed giving me about 12ft of separation between trailer and gen..
Vibration is not coupled to the trailer and the 12ft helps reduce noise inside the trailer..
