Honda extended run tank mod.
Camp__Forrest__
I KNOW that I have see a mod that allows one to connect a Honda 2000 to an external tank, but I can't seem to find it in the search tools.
Anyone have a link or the correct search terms. I tried "honda external tank", "honda extended run tank", "honda tank" and probably five other combinations and I can find it.
-2000 Chevy K3500 CC DRW 7.4L, Auto; 2000 Arctic Fox 1150 WB; 1999 Bayliner Capri 1800LS Outboard
-Air Lift bags, Torklift tie-downs, Superhitch w/48", Rancho RS9000X, K&N FIPK, MagnaFlow exhaust.
20 REPLIES 20
Camp__Forrest__
Reddog1 wrote:
I am going from a boat fuel tank to a NATO type gas can.
Wayne
That's what I'm thinking of when I say Jerry can.
Camp__Forrest__
TCcruzn wrote:
I used a jerry can no problem. I modified the screw on cap with a 1/4" bulkhead fitting. I installed a marine quik connect on the outside of it and 1/4" copper tube siphon on the inside using a 1/4" compression fitting. I also drilled a hole in the side of the can and intalled an air compressor bleeder valve I open when the genny is hooked up.
Excellent, thanks.
Reddog1
Camp, Forrest, Camp! wrote:
Everyone uses the boat gas cans, but I don't like the form factor.
Could one use the standard metal Jerry can with a siphon extending down to the bottom of the can?
Yes you can. The only issue is the large opening of the Jerry can allows an exceptional amount of vapor to escape. If you modified the Jerry can cap, you could put a small vent. The boat gas cans (boat fuel tanks) have a very small valve for venting.
I am going from a boat fuel tank to a NATO type gas can. I could simply drop the siphon tubing down the filler neck, but prefer to have a sealed system, with a small vent when needed. I also want the option of using the Honda/NATO can while going down the highway. Without a small vent, gas would probably splash all over the back of the TC.
Wayne
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
TCcruzn
2005 F250 4x4 CC SB V10,Rancho 9000,Tough Country winch bumper, 13500# Superwinch,Firestone airbags,Yaesu 2900
2008 Lance 830,200w AMsolar,BZ highvoltage controller
Yamaha EF2000
2012 Lund 1650 Rebel XL
1967 Honda Trail 90 (on the front bumper)
Camp__Forrest__
trail-explorer
I used an existing gas can I already had.
Bob
trail-explorer
I ordered caps from Ebay, and the ebay seller also had a package deal of billet machined oil drain extender tube and oil fill cap as a package deal, then everything else came from walmart boat department.
Ebay seller with all the doo-dads I bought
Bob
Carb_Cleaner
The Youtube video mentioned previously inspired me, but I haven't performed the mod to my cap, yet. I did, however, find a substitute for the Briggs 399517 shutoff. Stens 120-224 is a direct replacement for the Briggs shutoff for about 6 bucks.
From Ebay:
http://www.ebay.com/itm/131127363830?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
'13 F250XL SC gas 4x4 8', Camper & Plow packages, StableLoads, LT285/65R-18 Goodyear Wrangler A/T Adventure, 18x9 Ultra Motorsports "Phantom" wheels
'12 Wolf Creek 850 TC Coleman Polar Cub 9.2k A/C, 90 watt solar, dual propane & batteries, Maggie Rack
SCVJeff
OP- everything you need can be bought at Walmart in the boat section, except the Honda cap. Some buy another Honda cap and drill a fitting into the top, but I bought an aluminum cap off eBay all threaded and ready to accept the fuel fitting dejour. It's been solid for over 5 years, and the neighbors haven't complained once.
PS- The Red Cap I have isn't available separately any longer, but THIS is the same thing.
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
Reddog1
Please stay on topic, Honda extended run tank mod.
Wayne
Moderator
Toad: 91 Zuke
mkirsch
Nomad II
Nomad II
805gregg wrote:
If you are going to run the genset longer than the original tank your neighbors are going to hate you
Don't worry, the music will drown it out.
Seriously though, are you familiar with the EU2000? The air conditioner makes more noise.
I dunno. My neighbor's EU2000 was really bellowing when its mate ran out of gas and the A/C compressor kicked in.
Reddog1
I have had the extended tank mod (homemade) for several years. With two exceptions, I have only used it to keep the Honda fuel tank topped off. The way my Honda and boat fuel tank is setup, I run the Honda and boat fuel tank in place. The Honda pulls fuel from the boat tank, always leaving the Honda tank full.
I am going to replace my Boat fuel tank (3-gallon) with a 2-1/2-gallon NATO type fuel can. I have to make an adapter for the NATO can.
Wayne
Toad: 91 Zuke
Camp__Forrest__
AISURFFISH wrote:
who said this person was going to be camping anywhere near anyone else the guy simply asked for a link for some help so that he could run his generator I don't understand what is up with you people in this forum there's always a negative naysayer giving someone a hard time sorry if that hurt your feelings but deal with it
I don't think 805gregg was intending to be rude. He/she is just looking out for their fellow campers.
bb_94401
Here is a link to a thread on the Extended duration gas cap from a couple of years ago.
My reply in that thread shows how I modified an existing gas cap and the parts I used.
'05 Ram 3500, 4x4, DRW, LB, 6spd man, CTD, PRXB exhaust brake, Roadmaster bar
'01 Corsair 10'8" - 4,200 lbs., Xantrex XADC 80A, Link 20, 4-Lifeline GPL-4CT, PowerGate Isolater, 2 AWG wire, PI 30A EMS, 2 Honda EU2000i, parallel kit, ext. duration tank.
