โJul-27-2020 07:54 PM
โJul-28-2020 05:50 PM
Kayteg1 wrote:
Looks like you got blind eye on " near open windows or doors" recommendation.
It is always one of those hot topics, twin to fueling with running flame under refrigerator and you are not the 1st one with "direct vision".
Point is that you always hear from people who got away with the procedure, but never from those who failed.
Your choice where you want to go with it.
HERE is the link to propane conversion seller. You need to enter your specific generator model to get proper fit.
โJul-28-2020 05:42 PM
srschang wrote:
Our new Northstar TC has a cabinet specifically for a Honda or similar generator. It has an electric "inlet" wired into the cabinet, I made a short jumper extension cord from the genny to the "inlet". It also has a propane line plumbed into the compartment if you want to convert your genny to propane. And the best part, it has a MORryde sliding tray to slide the genny outside to fuel, start, & run!
The door to the compartment has a big vented section, I guess to let the genny cool down after you stop it and put it away. The door is also hinged at the top so it acts as an awning in bad weather.
โJul-28-2020 11:30 AM
โJul-28-2020 11:12 AM
Bert the Welder wrote:
Thanks Jim.
Was the plywood try to raise the floor of the cabinet up to get it at the level of the bottom lip, allowing for ease of sliding the gen in and out? Or something else?
โJul-28-2020 10:57 AM
โJul-28-2020 10:27 AM
Bert the Welder wrote:Kayteg1 wrote:
Page 7 in the manualmanual wrote:
If you run the generator in an area that is confined, or even partially
enclosed area, the air you breathe could contain a dangerous
amount of exhaust gas.
Never run your generator inside a garage, house or near open
windows or doors.
Yep. Like I said, that's not an exterior cabinet on a camper. Those are rooms in which people can be inhabiting.
Not sure why you can't see the difference?
โJul-28-2020 09:27 AM
โJul-28-2020 09:19 AM
jaycocreek wrote:
This topic is always immuzing..My last Class C had the generator compartment and the exhaust directly under the large sliding dinette window.. The exhaust was flush with the exterior siding directly under the window..
I can't see a problem running a honda in a sealed generator compartment with the exhaust pointed away or even bedder,on a sliding tray where it comes out of the compartment partially..
But then again,there are those who believe a Wave catalytic heater will kill you even though thousands of people use them in there RV..
โJul-28-2020 09:00 AM
โJul-28-2020 08:46 AM
windows or doors.
โJul-28-2020 08:43 AM
Kayteg1 wrote:srschang wrote:
I looked at the Northern Light website, and there's a picture of a Honda generator in the generator compartment with the exhaust pointing out of the compartment. Looks like it's hooked to a propane line in the compartment.
https://northern-lite.com/10-2excd-se-dry/
This one? I will not comment on gas tanks next to furnace exhaust.
The hose could be anything. Propane conversion kits come with huge diaphragm and I don't see it, so it is probably just a hose in the compartment. Doesn't look like generator could be started in this position anyway.
In my years of RVing I heard enough about deaths due owners hacking, or neglecting generator use, so would I be doing gasoline generator in camper compartment, it would have to have Venturi exhaust over the roof.
I will not ask you to try and report back as that might not apply after the try.
โJul-28-2020 08:27 AM
windows or doors.
โJul-28-2020 08:18 AM
bighatnohorse wrote:
There's lots of good information about using the Honda in a compartment in the Owner's Manual.
You might want to read it sometime:
http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
โJul-28-2020 07:54 AM
โJul-28-2020 07:47 AM
JimK-NY wrote:
I have no problem using my Honda 2000i in a compartment. The compartment was designed for use with a generator. It is sealed from the rest of the camper. There is a side door which must be latched open when in use. The rear door has a screen and can be closed even in use.
I did need to cut a piece of plywood and put on some edges to serve as a tray. I pull the generator partly out of the compartment for starting or adding fuel.
