Hood Vent Fan No Longer Working - UPDATE
SouthpawHD
My hood vent fan above the stove top randomly stopped working the other weekend. I have checked the main fuses, no luck. Also checked the switch on the fan and the wires are still connected. Inspected the fan and I see no visible issues with it.
Possible the fan just is done and I need a new one? If so, I have NO idea how to figure out what brand it is or anything like that.
Bought the rig new 2 years ago, so not like it is that old or anything.
Any thoughts and help on this would be appreciated.
Palomino SolAire 307QBDSK
2016 Chevrolet 2500, CC, 6.0L, 4.10
21 REPLIES 21
theczar
Have you tried it since? Were you cooking on the stove at the time? the reason I ask is that when it gets too hot mine has a shutdown and will start working again when cooled down.
mike-s
Most also have lights. Does the light work?
Jackfate
Check for voltage where wires hook to fan also check at switch.
SouthpawHD
Thanks for the tips! I will try some lube spray and checking where it's wired to.
As for checking to see if there is power to it, I will start with a tester and go from there.
Mfan
Is there power to it?
bigorange
We thought ours had quit working on our new trailer and discovered it is wired into the cabinet lighting...just a simple thought that might be the case here.
Not all those who wander are lost. - Tolkien
2018 Cherokee 235B 5W
2011 Ram 2500 CC SWB SLT 4WD 6.7 CTD 3.73
B&W Turnover Ball + Companion Slider hitch
2003 Sierra T22 TT - Sold
SidecarFlip
Motor is probably tied up. Take it out and squirt some PBlaster on the shaft at both ends, spin it by hand and reinstall it, Should work. If not, you can cross the motor numbers on the net and buy a replacement. Probably an import can motor of questionable quality anyway.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
