How do you secure your scissors steps?
hedgehopper
When we drive over bumpy roads, the folded steps unfold somewhat. So far they haven't dragged on the ground but . . .
Have you come up with a good way to secure the folded steps so they don't sag?
If you remove the steps and put them inside the camper, how do you secure them so they don't slide around and cause damage?
31 REPLIES 31
crosscheck
I fold them up and hang the bottom bar on the towing ball. Gravity holds them snug. 9 years and counting after 2 TC's and rough roads, no issues.
Dave
2016 F350 Diesel 4X4 CC SRW SB,
2016 Creekside 23RKS, 490W solar, 2000W Xantrex Freedom 2012 inverter, 4 6V GC-2 (450AH)
2006 F350 CC 4X4 sold
2011 Outfitter 9.5' sold
Some Of Our Fun:http://daveincoldstream.blogspot.ca/
Paradox123
Two EPDM bungee cords. Cheap and effective. I also have a padlock on them so they don't disappear.
dunegoon1
I have a pair of small safety chains for each side of the steps that clip to a small eye-bolt on the outer edge of the lower step on each side. Has redundancy since either chain will hold up the whole thing. About 10 years experience with this system.
hedgehopper
Wow, HMS Beagle, beautiful design and build!
Kayteg1, looks like I'll have to check out your link too.
Thanks to you two and to the previous contributors as well.
Kayteg1
I guess using search on this forum is unpopular?
So let me bring it one more time.
The way I did my steps give me everything.
- steps rest on top of the bumper, so simple securing will do
- I can enter my basement camper with steps on the bumper
-I can use my factory step if I am in hurry.
Here is link to the post https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28420784.cfm
HMS_Beagle
If you can find a way to really secure them in place, life is good. Having to remove them every time I drive for me meant I tried to avoid getting inside to get a drink, check things, whatever; due to the work involved in getting the steps out and hooked up. Also, unless the stairs are securely fastened at the top end, which makes them seem much less wobbly. This is what I did for the current camper, I did something similar for the last one and in both cases it was one of the most successful modifications.
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
Farmerjon
We remove ours and put them in a box at the front of the camper on the floor in front of the refrigerator. They are out of the way and can't damage anything.
2015 F350 Lariat CC LB 4x4 DRW 6.7, 6sp auto, 3.73
2000 F350 lariat SC LB 4x4 DRW 7.3, 6sp manual 3.73
1987 F250 Lariat SC/LB 4x4 SRW 460 4sp stick 4.10
1995 Jeep wrangler
99 Star Craft 953
jefe_4x4
My old narrow ones were bolted on and folded up and under the rr overhang with 2 bungie cords. The new G.Steps have pins and keepers for the top, which are hard to remove easily.
Just a caution for those that just remove them from the bar and store inside. I did that one time and the edge of the steps put a hole in the screen and and dent in the fiberglass door that remains distinctive, lo these many years later.
jefe
'01.5 Dodge 2500 4x4, CTD, Qcab, SB, NV5600, 241HD, 4.10's, Dana 70/TruTrac; Dana 80/ TruTrac, Spintec hub conversion, H.D. susp, 315/75R16's on 7.5" and 10" wide steel wheels, Vulcan big line, Warn M15K winch '98 Lance Lite 165s, 8' 6" X-cab, 200w Solar
Farmerjon
tuna fisher wrote:
I just lift them off and set them inside the door.
basslbbig wrote:
I take them off and put them in the camper.
X3
1995 Jeep wrangler
99 Star Craft 953
basslbbig
2005 Silverado 2500HD 6.0 SB SRW,Rancho 9000,HM Stableloads,Hellwig SB
2001 Fleetwood Angler 8C
2006 19' Reinell
1969 Z28 Camaro
Super_Dave
Mark,
That looks familiar.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
msiminoff
Cheers
-Mark
'04 Alpenlite Saratoga 935, 328W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins,Vision 19.5 w/M729F's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Rancho RS9000XL
The Overlhander Blog
tuna_fisher
2001 GMC DM, 1995 Lance Lite, @005 Eclipse Toyhauler, Toy's!;)
wcjeep
If these are the Torklift glow steps, have you tried the new landing gear? It works great. The bolts that arrived with mine were wrong. It can easily compensate for unlevel ground.
Landing gear
Kayteg1
I made the design that folded steps rest on the top of the bumper, so only need bungee cord to secure them there.
Pictures in my first topic.
