How do you secure your scissors steps?
hedgehopper
When we drive over bumpy roads, the folded steps unfold somewhat. So far they haven't dragged on the ground but . . .
Have you come up with a good way to secure the folded steps so they don't sag?
If you remove the steps and put them inside the camper, how do you secure them so they don't slide around and cause damage?
31 REPLIES 31
Artum_Snowbird
I built a long rod with a washer at one end that went up against the steps. At the other end, the rod went through the step holding framework. The rod had a hole in it that I would put a push through clip through on the other side of the frame.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
Joe417
I use a 1" aluminum strap screwed to the back edge of the top step.
The strap has a slot in it that fits over an eye bolt screwed to the back of the bottom step.
Solid fastening.
Joe and Evelyn
