โSep-19-2018 07:25 AM
โSep-24-2018 01:25 AM
myredracer wrote:
Beware of some internet advice like from this dude who used silicone on his camper. He even made a short how-to vid here. Wow. Just wow... :S
โSep-24-2018 01:02 AM
myredracer wrote:
Wondering if it's perfectly okay to put new Proflex over old stuff without having to remove any of the old caulk? I removed some along the top of the fender skirt a couple of seasons ago using white gas and plastic scraper. Even tried a little heat from a blow dryer. OMG, not easy... Would rather just add more even if it doesn't look as nice.
โSep-23-2018 08:50 PM
โSep-23-2018 08:54 AM
Hannibal wrote:So true!!! I just hate that.
Would be really nice if Dicor would offer their lap sealants in smaller squeeze tubes for touch ups.
imq707s wrote:Some people refer to any caulk as "silicone". Ordinary 100% silicone caulk on the exterior is a no-no. For one thing, unlike RV exterior caulks, can't put fresh silicone over cured silicone as it won't adhere.
I thought silicon caulk on a camper/trailer was a big no no?
โSep-23-2018 08:11 AM
Most campers (all?) have the trim caulked with silicone to start with. I am slowly getting to all the exterior trim and replacing the silicone on ours.
This is exactly what I noticed when looking at new trailers. I was really surprised. Guess I should not have been. I will start to replace the silicone with something else too. Just not sure what yet. I was using 3M 4200 marine caulk and it worked great. I think it only comes in white and the new trailer is not white so might look funny. Need to check if it comes in clear.
Comes white or black. Most of the trim is black so that should work.
โSep-23-2018 07:34 AM
I'm looking for a better lap joint/non sag type of sealant.
โSep-23-2018 06:00 AM
โSep-23-2018 05:36 AM
imq707s wrote:
I've had our 2011 Crossroads Zinger for close to three year now. When I first got it I went through everything and cleaned out the old caulking on all of the joints, and redid it. Then last summer I noticed that some of that caulking had started to crack and look pretty bad so I redid a bunch of it again.
And now this summer/fall I've started to notice that once again, I can see several spots were the caulking around things has started to pull away and/or crack...and needs to be redone.
I've always used the high quality (and expensive) RV caulk, and it just doesn't seem to last very long.
Is that pretty normal, or am I doing it wrong??
โSep-23-2018 05:21 AM
โSep-23-2018 04:58 AM
โSep-22-2018 11:11 PM
proxim2020 wrote:
On the roof I've switched over to Eternabond tape wherever I could. Do it right the first time and don't worry about it again.
โSep-22-2018 08:55 PM
โSep-21-2018 07:46 AM
โSep-20-2018 11:15 AM
