โJun-14-2015 09:07 PM
โJun-18-2015 01:27 PM
โJun-18-2015 12:56 PM
2BLAZERS wrote:
We were camped this past weekend in Harris Beach State camp ground with full hook ups. Was hooked to the water provided and had left it on since we arrived the evening before. We were at the play ground and I ran back to the camper to get something....and saw water dripping under the front of my truck bed onto the ground and a good sized puddle. That ain't right!!
After looking in cabinets and the step to the cab over bed....
So I had a pin sized hole in the 150PSI pressued hose after the pump that feeds the water system. It was basically a little tiny streaming into the basement of the camper. That ain't good.
So turned of the park water and tried the pump, leak is the pressured side of the pump, it still leaked. So no water to use, not good.
We ended up running to ACE hardware store, bought 1 foot of 150PSI 1/2 tubing, a coupler, razor hose cutter tool, and two more small hose clamps. Cut about 8'' of the old pipe that had the pin sized hole and added the new 1 foot section. Been working great since. This is all under the step into the cab over bed. Tight space. You could not hear the water peeing since we were hooked to the provided water spigot.
If we had been using our tank and water pump we would have found this much earlier, likely that prior night shortly after hooking up.
And yes we usually turn water off and the water heater off if we are going somewhere for the day, but we were just down at the play ground.
I have the step open with a fan blowing down there, hoping it drys out in the hot weather we are having. This weekend will be opening up the corner of the underbelly to make sure the insulation is dried out. Thinking some of it will be wet still.
โJun-18-2015 12:44 PM
โJun-18-2015 11:22 AM
Bedlam wrote:
Even on hookups, we typically fill the fresh tank and pump from it. This prevents growth or stale water in our tank since we camp at least twice a month all year.
โJun-17-2015 07:14 PM
โJun-16-2015 01:52 PM
โJun-16-2015 09:03 AM
โJun-16-2015 04:35 AM
โJun-15-2015 07:53 PM
coolmom42 wrote:
Always leave the water pump off when not in the camper for more than a few minutes. If there is a leak, you should notice it while you are there...
coolmom42 wrote:
...And if you are hooked to city water---turn it off at the spigot when you leave.
โJun-15-2015 08:25 AM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โJun-15-2015 08:23 AM
โJun-15-2015 08:17 AM
โJun-15-2015 07:30 AM
โJun-15-2015 06:40 AM
