May-15-2015 09:40 AM
May-15-2015 05:06 PM
May-15-2015 03:59 PM
thcguy12 wrote:
Really - I think it's applies to most rvs, campers, travel trailers, etc.
May-15-2015 03:37 PM
May-15-2015 02:59 PM
May-15-2015 12:50 PM
valhalla360 wrote:
I'm confused: How did you get the trailer in if you can't get a tow vehicle to it?
A floor jack to raise the wheels, will work. I wouldn't count on using the stabilizers to lift the trailer. That's not what they are designed to do.
May-15-2015 11:15 AM
May-15-2015 11:14 AM
downtheroad wrote:This is what I would do and have done it before!
Use a bottle jack on the low side. Raise it enough to level and then put blocks under the wheels and lower it down again.
or
Dig around and under the tires that are on the low side and let it settle into "level" in the hole.
May-15-2015 11:12 AM
May-15-2015 10:47 AM
May-15-2015 10:39 AM
thcguy12 wrote:
Well we pulled in and then I have to drive out over a couple huge boulders which ripped up the under cairage of my car (not too bad I hope). It was the only way to squeeze it into this little oasis of a spot on our property. It will never be moved out of there.
Don't have a regular jack.
May-15-2015 10:37 AM
May-15-2015 10:35 AM
May-15-2015 10:32 AM
May-15-2015 10:27 AM
