โJul-31-2022 03:19 PM
โAug-03-2022 05:39 AM
โAug-02-2022 04:07 PM
Huntindog wrote:QCMan wrote:I'd rather spend the 13.00 on beer for after I finish the job using a drift... Heck, in a pinch, I have used a screwdriver.
Maybe try this non existent tool
https://www.harborfreight.com/3-jaw-pilot-bearing-puller-4876.html?utm_source=google&utm_medium=cpc&utm_campaign=12144811130&campaignid=12144811130&utm_content=117789253198&adsetid=117789253198&product=4876&store=726&gclid=EAIaIQobChMI3K3u7uul-QIV0WxvBB28SgqQEAQYBCABEgLoVfD_BwE
โAug-01-2022 07:20 PM
โAug-01-2022 07:27 AM
โAug-01-2022 07:19 AM
โAug-01-2022 03:25 AM
โJul-31-2022 10:11 PM
โJul-31-2022 08:32 PM
โJul-31-2022 08:14 PM
Baja Man wrote:
Hello all--
I wanted to see if anyone has a method for removing brake drum/hub bearing races from trailer brake drums using a simple shop press.
I know there are kits that use machined alum discs of various sizes to install races and seals (either with a hammer, press, and air hammer) but have never seen how to remove them using a shop press.
I know how to remove races using a brass drift and hammer. You must access race at an angle, as the race can not be hit vertically with the drift. This is what makes using a press a challenge.
So.....how can races be removed from brake drums using a shop press?
Maybe it's so simple, I can't see it or think of it!!!
Thanks!
โJul-31-2022 07:26 PM
JRscooby wrote:time2roll wrote:
The artist missed the fact the shape of hub will not let anything vertical reach the race. Driving them out, always working at angle.
OP, you might cut a bar the right length to lay on the race, then push the center.
Big races, with alloy hubs, where I fear the impact might distort the hub, I have just ran a bead in center of face. The weld will pull the race, let it just slide out.
โJul-31-2022 07:21 PM
QCMan wrote:
How about using a puller instead of pushing it. There are a lot of pullers with adapters to hook just about anything. Some auto parts stores lend them out with a deposit.
โJul-31-2022 07:03 PM
โJul-31-2022 06:30 PM
JRscooby wrote:I agree but things can vary. I am not looking at it. Even a picture may not show well due to the angles etc. If the OP thinks there is an edge to catch then will need to make or buy the tool.
โJul-31-2022 06:19 PM
Huntindog wrote:
As an owner of a 30 ton press, I woudn't bother. I am sure I could rig something up, but it would be much easier and faster to just hammer them out with a drift
