How To Video: Changing a Duramax Fuel Filter.
deltabravo
If I'm slow doing it, it might take 10 minutes.
I've never paid a dealer to do it because it's easy to do if you are the type the likes to do your own maintenance.
A Dealer charges my dad at least $100 for the filter change on his truck.
This video applies to LB7-LMM for sure. I think LML and later use a different style filter.
2009 Silverado 3500HD Dually, D/A, CCLB 4x4 (bought new 8/30/09)
2018 Arctic Fox 992 with an Onan 2500i "quiet" model generator
9 REPLIES 9
deltabravo
edatlanta wrote:
I just remove the passenger side battery for access. I just changed the filter on my 2006 LBZ for the for the 20th time so I've pretty well got it down now.
Good idea. ๐Ÿ™‚
I had an LBZ concurrently with my LMM. LBZ was easier. I could also pull the filter out the top.
edatlanta
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
larry_barnhart
I have been changing our fuel filter each summer but can pull it up and out. Carry everything to do the work incaseas we travel.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
deltabravo
lazydays wrote:
They are easy to change but takes me more than 10 minutes just to drop the fender well. Now the L5P's are real easy.
Access door in the fender well is a huge time saver.
deltabravo
bob213 wrote:
I always carry an extra filter.
I need to carry one too.
FishOnOne
The Ram/Cummins guys could really use that access door to access that pesky oil filter.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
lazydays
Very Patient Wife
Two Boys & a Girl
2013 Keystone Avalanche 345TG
2016 Chevrolet Silverado 3500HD 6.6L
jaycocamprs
LML still uses that filter. L5P does not
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
bob213
Thank you. Good video for those who have done it and those who have not. Wheel well door really makes access easy. Even though I have done this numerous times it's a good refresher to jog my memory. Everyone should know how to do this as bad fuel will put you on the side of the road quickly. I always carry an extra filter.
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
