May-11-2013 09:31 PM
May-14-2013 05:42 AM
APT wrote:Yeh depending on how well I can get the TT on my street will determine weather I get a have to get a newer F150 with much higher tow rating or a F250 which is what I want.
Thanks for clarification. If only towing home, then I would not bother with spending anything on the truck if you plan to sell it anyway.
Mirrors for $39.
May-13-2013 11:06 AM
May-13-2013 10:16 AM
APT wrote:I could not agree with you more. That's why longest trip will be from the dealer. We will stay close to home until I upgrade the TV. We have several campgrounds less than a hour drive from home. I will check out those mirrors also.
I don't think you'll be very pleased with how well a 1998 F150 tows a 6000+ pound TT.
Keep overdrive off. Get some towing mirrors, I like the CIPA custom fit ones when I has a 2003 F-150. Flush and change all your fluids.
May-13-2013 09:58 AM
camperforlife wrote:What size boat do you have? Thanks TecheMan
I found that my 28 ft trailer requires less of a wide turn than my boat. The boat axles are further back on the trailer requiring a wider turn and the boat is also is slower to respond when backing. The trailer will always jackknife quicker backing than the boat. Just like anything else, a little time, a little practice and you will be a pro with either.
May-13-2013 07:41 AM
May-13-2013 07:32 AM
May-12-2013 08:24 PM
May-12-2013 07:56 PM
May-12-2013 04:24 PM
6dot6 wrote:Yeh you right I will turn as wide as I can coming on to my street. I was concerned with my narrow street that I couldn't turn wide enough. But I feel better now that the track of the TT won't be that far off of my boats track. I thought it might be a whole lane different or so but it sounds like it's about a half lane or so.
never hurts to go wider than you need bud. easier to come back from a wide turn than to have to back up to fix a turn you cut too short.
May-12-2013 03:17 PM
May-12-2013 01:03 PM
skipnchar wrote:I have a F150 is your trailer a 28BH?
A LOT about just how wide you have to turn will depend on your tow vehicle. I have only an alley width (with utility poles right on the corner on each side) to get to my parking place. The turn was not possible with my F 250 and 58 feet overall length but it's a fairly easy turn with the F 150 55 feet over all length, combination. Same trailer making the same turn.
May-12-2013 12:07 PM
TecheMan wrote:Dtaylor wrote:Thanks I am extremely good at backing my boat. The key is knowing where your wheels are when starting to back up. They will start making the turn from that point and continue to do so. The tail will swing to follow the wheels. So if you get your wheels where they need to be before backing half the job is won. My biggest concern was will I make wide turn with this long TT and still not beable to get it on my street. Thanks TecheMan I appreciate this I really do. It is so nice to have a place like this where others are willing to help one another with stuff like this.
I tow a 21ft Stratos and a 30ft TT. The main issue I had, and still have sometimes is judging distance when backing so I always use a spotter. Turns, especially sharp turns, you have to watch out more for tail swing on a TT that you do not have with a bass boat. The wheels on a TT are more center mounted than rear mounted like on a boat trailer. Other than the fact that a TT catches more air, I really cannot tell much difference as far as highway towing. I think the biggest issue is your confidence/comfort level. As for the width, from outside to outside, they are about the same. We have some really narrow roads that my butt cheek pinches the seat on when towing both, so that part is the same. I think you are over thinking. It becomes second nature just like it has with your boat
May-12-2013 11:55 AM
May-12-2013 10:21 AM
TecheMan wrote:Taz 23 wrote:So it tracks similar to the bass boat. I noticed the wheels on the TT are further back just in distance than the boat but they are underneath the TT where the bass boat the wheels are toward the back of the trailer but outside makeing it's wheel stance wider than the tow vehicle. I currently have no trouble getting my bass boat home and in the yard. I have a two car driveway with the right side well open to the back yard.
Towing the travel trailer will not be any more difficult than your bass boat. You will however want to keep an eye out for overhead obsticles (such as tree branches) that you would not even notice with your boat. Take your time and practice and you will soon be able to pull it and back it up easy enough.
Thanks Techeman
