โDec-31-2014 07:06 AM
BarneyS wrote:
the thing you are thinking about is that in order to unhook and remove the WD bars with the Husky Centerline hitch your truck/trailer would need to be pretty much in a straight line with that hitch. The reason is that there are compression washers in the bar sockets/hitch head that always try to keep the bars in a straight ahead position. This is what makes the hitch resist sway. However, that same pressure that keeps the bars in the straight ahead position also make it hard to move them away from the A frame for removal off the L shaped brackets if the truck/trailer are not lined up straight.
โDec-31-2014 07:28 AM
โDec-31-2014 07:20 AM
