installing 30 amp power at home
Pig-Smoker
I'm thinking of installing a 30 amp breaker box and run it from my garage to my camper. Should I use a 220 or 110 to supply the power for the 30 amp. I'm not really an electrician but this I can do , just not sure if the 220 would be too much and fry my converter.
2007 2500HD Chevy
2008 28ft Dutchmen
19 REPLIES 19
Chuck_thehammer
I ran 150 feet of 8 gauge.. and purchased the RV connector at an RV shop.
30 amp 120 volt A/C....
trailer plugs right in.. No adaptor.
time2roll
120
120
120
120
120
Use a single breaker. 240 will let the smoke out of more than just the converter.
Cobra21
It needs to be 110 or 120 volts a.c. Also use the 30 amp circuit breaker
with 10 gauge wire. I wired one for mine and really like it. If you don't
have a 30 amp. outlet, you can probably run everything except the roof air.
Brian
If you run more than 25 feet of wire, you may need to go from
10 gauge to 8 or even 6.
gbopp
30 AMP RV Service
Click on the 30 AMP link.
TucsonJim
It's a 120v, 30A alternating current hook up, not 240V.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
