Interesting engine
4x4ord
https://www.roadandtrack.com/new-cars/car-technology/a19909520/gas-diesel-engine-reactivity-controll...
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
6 REPLIES 6
LIKE2BUILD
Home Skillet wrote:
Here's an even better solution.
Ford two stroke engine
Here's a nice video showing animation of the Achates Opposed Piston Engine.
'14 Ram 2500|Crew Cab Long Bed|4X4|Cummins
Curt Q20 with Ram 5th Wheel Prep
2000 Crownline 205BR
1997 Ranger Comanche 461VS
'01 Polaris Virage TX PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (21, 15, & 13)
1 forgiving wife!!!
Groover
4x4ord wrote:
K Charles wrote:
The Otto cycle has been around for almost 150 years and many things have been done to it since the invention. It will never be 100% efficient because the piston stops twice every time the heat is turned into energy.
Gasoline engines will never be 100% efficient but that 60% efficiency number of the dual fuel engine is pretty close to that of electric cars.
I have heard that in the late sixties state of the art was about 20% so this engine would only need about 1/3 as much fuel to do the same job. That is quite remarkable. That also means that only 1/6 as much energy is released as waste heat. Nothing man made is every going to be 100% efficient but this would be a huge step that direction, if it even makes it to production.
By the way, the piston stopping has almost nothing to do with the efficiency loss. The pistons are stopped smoothly with the energy in them being returned to the crankshaft. If you want to know where the energy is going just check out the lost heat and why it is being dumped. Start with the cooling system, then hot exhaust gases, losses from the oil pan and block, etc.
4x4ord
That is an interesting engine as well but not nearly as efficient. It sounds like meeting emissions is a bit of a challenge as well. Why do you say it is a better solution than the dual fuel?
B&W Companion
4x4ord
B&W Companion
Home_Skillet
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
K_Charles
