Interior lights issue
1buda
Just changed out the converter, wired it up to a new spade type fuse block. Converter is working like it should, battery is up to par. Now I have interior lights in the front part of the trailer and now no lights in the bedroom or bathroom (rear of the TT). What I did not hook up was the wire for the antenna. All the bulbs are good. I'm going to try to apply power to the wire that I left out and see what happens.
2 REPLIES 2
1buda
Gdetrailer wrote:
Yep, hook up the "antenna" power lead.
In many cases multiple items may and often share circuits, antenna power is most likely sharing the lighting circuit.
Thanks, will hook it up tomorrow it's cold and snowing...
Gdetrailer
