Intermittent brakes
toytacoma8
Trailer brakes started to become intermittent on my spring sale recently. Towing with a f250 with built in controller. I replaced the male end of the 7 pin plug on the trailer and it seemed to fix it but the problem slowly came back and has gotten worse. They occasionally work after a couple seconds of applying the brakes. I also notice that my break away switch doesn't seem to work. Any ideas if these could be related? I've traced every wire I can find but have found no damage.
2 REPLIES 2
Nicholsfamily05
Here is my thread of what happened to my brakes.
http://forums.goodsamclub.com/index.cfm/fuseaction/thread/tid/28875497.cfm
Turned out to be the magnets and wires.
2016 Ram 3500 4x4 Big Horn Crew Cab, SRW. Cummins Turbo Diesel Automatic 68RFE Trans
50 gallon diesel Transfer Flow tank with the Traxx 3 system.
2017 Sierra FLIK 5th Wheel
42' Front Livingroom, 15K
Hydraulic level up system
bobndot
could be many things to test . here is a thread on it. you might pick up something that works in your case.
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23205219/print/true.cfm
one more bit of info. check magnets
https://www.etrailer.com/question-30816.html
