Jan-02-2021 12:57 PM
CB
Channel 17Redneck Express
Jan-04-2021 02:22 PM
mkirsch wrote:
Isn't it curious how you look at a product that has an overwhelming number of 5 star reviews, but those two one-star reviews STILL make you question purchasing the product?
Of course 90% of those 5 star reviews are from people who "review" the product the minute they get it home from the store, "It's all shiny and new! Great product!" There again 90% of the 1 star reviews are from people who either have irrational expectations or abuse the product, "Does not stand up to being beaten repeatedly with a pickaxe! Horrible product!"
CB
Jan-04-2021 04:40 AM
Jan-04-2021 03:39 AM
wopachop wrote:
Most people here drive to campsites and plug into 120v. So the batteries never get cycled. Never see a strong charge. Sits there on solar and ruins the flooded battery.
If that same person did not have solar their batteries would self discharge and then get recharged at a high amp rate. Which i think would improve the life of the battery. Sitting there on float all day is no bueno. From what ive read on the trojan website regarding flooded batteries.
Makes me think some of those bad costco reviews are probably from people with solar hooked up and never give the battery a proper charge.
Jan-03-2021 11:45 PM
pianotuna wrote:
JoeChiOhki,
I'm aiming at 600 amp-hours @ 12 volts myself. I'll be using SiO2 batteries.
JoeChiOhki wrote:
Do SiO2 batteries require special charging sauce like the LiPOs where DC-DC charger is needed? My equipment is all old school so the alternators a bit more on the "dumb" side and has worked well charging my battery banks back up going down the road with the 100amp charging setup I use.
Jan-03-2021 11:33 PM
pianotuna wrote:
JoeChiOhki,
wopachop wrote:
I still think the reason costco batteries are getting a bad rap is because of solar charging and the internet.
People think their solar is maintaining their flooded batteries. Which is not true.
Those same people have a battery fail and within 5 minutes they sign into costco and leave a bad review.
StirCrazy wrote:
when I put GC batteries in mine I measured the size of each one, then measured the space and opening I had to get them in. granted I was putting them into an older one that wanst made for more than a car battery so I had to turn the battery compartment into a small storage compartment and use the storage compartment for my batteries. the deciding factor on the batteries was the door opening. the 210AH batteries left me 3/4" of clearance through the door, the 220AH set would only leave me 1/8" and the 235AH were bigger than the door. I also bought a watering kit as although the space was bigger inside there just want enough room to get a turkey baster or measuring cup in there to add water, or your head to see how far it was down. the watering kit works awsome, I just plug the pump extension into the harness put the end in my distilled water and pump it till it wont pump anymore. fills the batteries perfect and takes two min. so now I do this every time I am getting ready to leave instead of the twice a year check I do on the 5th wheel. I am buying a set for the 5th also I like them so much.
Steve
CB
Jan-03-2021 12:50 PM
pianotuna wrote:Kayteg1 wrote:
But then you drive Ford right?
My Fords over the years always had charging at 14.5V or above and that was killing batteries prematurely all the time.
My Ford e-450 does not exhibit that sort of charging behavior--it is a 2005.
Jan-03-2021 11:49 AM
Jan-03-2021 10:52 AM
Jan-03-2021 10:41 AM
wopachop wrote:Yes and the other half cycles them flat dead between trips.
Jan-03-2021 10:03 AM
Jan-03-2021 09:56 AM
Jan-03-2021 08:51 AM
Jan-03-2021 08:39 AM
Jan-03-2021 08:37 AM
Jan-03-2021 08:09 AM
deltabravo wrote:
Because I have an inverter/charger, the batteries gassed more when charging, losing water.
I killed the batteries due to poor maintenance.
