work2much
Apr 11, 2019Explorer
Inverter charging the camper from the trucks batteries.
Has anyone installed an inverter in their truck that they use to charge the camper?
My thought is that converting to 120v and connecting to the campers 120v system would allow a more stable charging source using the campers charger rather than the trucks alternator and all the DC line loss/heavy cable and possibly inconsistent voltages.
I would install a battery isolator that is switched by the ignition circuit as well as an in cab switch. Most of the time we don't need any more than what our solar provides but it could be handy to add charging while we drive when we get multiple cloudy days.
The inverter mounted in the truck would also give us a 120v power source when we don't have the camper with us. Our campers inverter/charger is adjustable for charging amperage so we could keep the amperage at a level that the trucks alternator could handle.
Potential issues could be engine compartment heat and protection from the elements. Maybe the inverter could be mounted in the cab.
Another negative could be the loss of efficiency converting 12v to 120v and back to 12v. Given that the trucks engine has unlimited power for this application though I think that may be a moot point?
Thoughts?
Thoughts?
