Is it wise to invest in a cover for my TT?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
โOct-19-2014 10:12 AM
It is our first TT and were able to use it this year and a BIG thanks to this forum for everything I have learned so far, you all have helped make it a fantastic experience! If it helps, it is a 24' Ameri-Lite SS. Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โOct-19-2014 11:52 AM
The only downside I found was that I didn't use the cover year round because of the difficulty I had putting it on and taking it off. This is probably due more to my physical abilities than any flaws in the cover design. It did require someone to get up on the roof and pull the cover over the edges. I usually only covered it after I winterized it. My cover had the zippers at the doors so that allowed access to the TT to check for unwanted trespassers of the 4 legged variety during winter storage.
I firmly believe that keeping my TT covered and well maintained were the reasons why I got top dollar when I sold it. I am currently looking for a cover for our new (to us) RV for the upcoming winter.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โOct-19-2014 11:46 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โOct-19-2014 11:22 AM
I don't recall anyone talking about that first hand, but rather thy read, or heard about it.
One good tip is to cut slits in tennis balls and put them on the gutter extensions. It will keep the extensions from cutting the corners of the cover.
Our cover is actually designed for a motor home longer than our trailer (by almost 6 feet) so I have to roll the excess up and tie it on the tongue, and it doesn't have a zipper door, which I wish it did, but I got it for $126.00, so I'm not going to complain much.:) I can actually loosen the tie rope and there is enough room to squeeze into the trailer if I have to.
This will be the 4th year (second trailer for it) and it's still fine.
We cover ours because where we have to park it is under trees, and I like the extra (double fabric in the roof) protection from small branches, ice dropping, etc.
2011 29' Kingsport 28RLS by Gulfstream
2013 Ford F150 Ecoboost 4X4 Supercrew
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โOct-19-2014 11:21 AM
ellibri wrote:
I am able to store my TT on my property.
Is a carport an option? Considering life expectancy of the covers, it might be cheaper, less hassle, and would eliminate the chance of scratching.
2014 Keystone Bullet Premier 22RBPR
2013 F-150 XLT Supercrew 4X4 Ecoboost Max Tow
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โOct-19-2014 10:58 AM
A garage is a better idea but, obviously, much more expensive.
I cover our Southwind and have not had any problems with the cover rubbing the paint.
And, we get a lot of winter wind in my area.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โOct-19-2014 10:40 AM
The more you can keep it out of the sun and rain the longer it will stay new.
I've been using an ADCO cover for 10 years and it has held up well enough.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โOct-19-2014 10:27 AM
2010 Subaru Impreza Sedan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โOct-19-2014 10:22 AM
That said, I would only purchase the absolute best cover with the softest interior I could find. Some have reinforced corners.
Be aware however, that even the best will probably only last two to four years. Make sure you get one with a zippered access door to allow you inside if needed.
Good luck
Ron
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
