Is my battery being properly charged when TT is plugged in?
MicahDD
Hi all, I recently bought a 2006 Sun Valley Roadrunner, it's a single-axle small TT.
My question is... will the RV battery on my Roadrunner be charged and properly maintained by me simply plugging the TT into one of my normal household outlets?
On my larger (and soon to be gone) Prowler TT there's a charge wizard, which my research suggests will charge and then "maintain" the battery on the Prowler when the TT is plugged into my house.
But I don't know if my Roadrunner will do the same thing? Should I always remove the battery from my Roadrunner and put it on a battery tender when I'm not using the trailer? Or can I just leave the battery connected and plug the trailer in and everything will be fine?
Thanks for the help, I'm really a novice about all this stuff!
6 REPLIES 6
MicahDD
Thanks all. I checked my power converter, it's an Elixir EX-45, which as bldrbuck says provides a 3amp trickle charge, but as ddrueckh said is not a 3-way maintenance charger.
So basically I think that if I'm going to not be using the trailer for long stretches I need to remove the battery and put it on my battery tender. That, or replace the power converter with one of these "intelligent" converters that's also a 3-way charger. I doubt I'll do that unless the current converter dies.
Thanks all!
bldrbuck
Most converters only sypply a small amount of current to charge the battery. That is usually about 3 amphers. That is fone of the battery is fully charged. If it is discharged more than 10 per cent use an external charger to top- it off, then the converter should keep it up.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 35' King of the Road 5er, 192 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 2 Trogan T105 Batteries, Me, my wife and 2 maltize furkids.
pwrplay
I leave mine plugged in all the time to keep the battery charged up by the built in Inverter/Charger. When in storage I pull the battery out so that it does not run down due to phantom power sources and the propane detector.
I need to install a battery disconnect switch so I don't have to keep removing the battery when put in storage since I don't have access to hydro at my storage facility.
2015 Grand Design Reflection 323BHS
Curt Q16 w/roller
2009 Ford F250 Super Duty CC 4x4 6.8L V10 4.10 "Big Bubba"
2014 Nights Camped: 42
2013 Nights Camped: 32
ddrueckh
Probably not. You need a 3 stage charger to properly charge and amintain your batteries...
2011 Chevy Silverado 2500 Crew Cab 4X4 DMax
2000 Jayco QWEST 244B
MicahDD
Bonefish wrote:
Only you can tell by looking at the installed power pannel and checking the model number on the web.
Gotcha. Will dig deeper and see what I can figure out, thanks.
Bonefish
