โAug-02-2014 10:30 PM
โAug-04-2014 02:12 PM
โAug-04-2014 11:38 AM
myredracer wrote:
If checking the water system, if water leaks onto the floor, you should get it up immediately as it can cause some significant damage like MDF "wood" which soaks up water.
As said above, it sounds like it may not have been winterized.
I would doubt it is PEX that has cracked. It's more likely to be a fitting somewhere. Fittings, like elbows for example, can be in hard to get at locations too. I would leave a faucet open when you first turn the water on so that the lines do not get full pressure then when it looks okay, turn the faucet off. I would start by looking for fittings under dinette seating, under sinks, hot water tank, etc. and see if they look okay. Some can be hidden inside a vanity cabinet and you can pry off the luan plywood in some cases which is just held in place by thin small staples and easily pulled out.
The toilet valve could be leaking or it could be the fitting attaching to the toilet. The braided hose may have split.
The faucets all have a swivel adapter that connects the PEX to the faucets. These could possibly be damaged.
The P-traps under sinks and the tub/shower could be damaged if water was left in them over the winter. Easy to check the ones under sinks. Their should be an access cover of some sort for access to the one under the tub/shower.
I would get a couple of friends or family to act as spotters as you slowly turn the water on and look for leaks. When you think you have got it all fixed up, I would recommend getting a regulator with a pressure gauge on it. Pressurize the system and see if the pressure holds. I would leave it overnight too. You *could* buy a gauge and fittings from HD and mount the gauge inside somewhere on a cold water line so that you can also monitor CG pressure.
โAug-04-2014 10:42 AM
โAug-03-2014 10:59 AM
โAug-03-2014 10:40 AM
easytoplease1955 wrote:Well, almost everyone has dropped polybutylene pipe and gone to another type, mostly PEX. The PB pipe does tend to slip out of fittings but freezing will break it like any other. Visual inspection is enough to diagnose the cause of leaks.
Sorry westend about the caps and ty for the reply. Does the pipe give much problems or is it normally the fittings and how expensive are the sharkbites? Also, do you think Lowes or HomeDepot may have them?
โAug-03-2014 08:11 AM
I looked at the eternabond on graingers website and man they are proud of that stuff. Very high dollar. Any other places you suggest I check for the eternabond because I hear it is really super good stuff?
โAug-03-2014 06:46 AM
โAug-03-2014 06:45 AM
โAug-03-2014 05:04 AM
keymastr wrote:
be sure you use a pressure reducer on the water inlet or you can blow the lines off. City water pressure is too strong for an RV in most cases.
โAug-03-2014 04:41 AM
โAug-03-2014 04:36 AM
โAug-03-2014 04:20 AM
โAug-03-2014 01:00 AM
โAug-03-2014 12:32 AM
