โAug-14-2021 02:57 PM
โAug-19-2021 05:40 PM
It was factory - the generator and propane tank were not huge. If I come across it again, I'll post the info
โAug-19-2021 06:40 AM
afidel wrote:It was factory - the generator and propane tank were not huge. If I come across it again, I'll post the info2012Coleman wrote:
I recently saw a small TT that had an Onan generator powered by propane installed forward on the AFrame - it was used to power the small AC unit. So yes - they do exist.
Was that factory or aftermarket? Also if your wanting to tow with an SUV putting that much weight up front seems like a bad idea since basically 100% will go to tongue weight.
โAug-18-2021 02:09 PM
โAug-17-2021 12:54 PM
โAug-17-2021 12:51 PM
โAug-17-2021 11:23 AM
โAug-15-2021 09:54 AM
rexlion wrote:
It could help if you were to tell us the brand and model of trailer you're interested in. There are too many variables, depending on the mfr.
โAug-15-2021 05:51 AM
Bordercollie wrote:
There is a new generation of very small travel trailers apparently intended for towing by SUV's. I have watched some YT videos and have some questions:
1. Do you need to install accessory wide view mirrors on your SUV?
2. Looks like most don't come with typical built-in Onan generators, are there options for installed generators and converter/chargers and a house battery?
3.Is the toilet a typical RV flush-type connected to a fresh water pump?
4.Is it necessary to install anti-sway device on your SUV?
5.Is the fridge normally automatic for propane, 110vac camp power, or 12 vdc powered by car alternator while driving?
Thanks!
โAug-15-2021 05:44 AM
โAug-14-2021 05:26 PM
โAug-14-2021 05:11 PM
โAug-14-2021 03:43 PM
