Just turned 150k!
tsetsaf
The truck just turned 150k. That is 90k miles under our ownership. Other than routine maintenance I have only had to replace a few items: rear axle seal at the hub, exhaust brake vacuum pump (lasted the standard 70k) and front end joints (2k miles ago). Say what you will about brands but this 06 Ram is one solid truck. With the price of new diesels I don't see myself getting rid of it anytime soon.
2006 Ram 3500
2014 Open Range
"I don't trust my own advise!"
3 REPLIES 3
valhalla360
Nomad III
Nomad III
Congrats and good luck going forward but 150k is nothing on a base gas engine let alone a diesel.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
e-light
I have seen many hot shotters with over 1,000,000 miles on those engines. Routine maintenance and watch temps and fluid levels and they should last. If something is hot or low on fluids it needs attention asap...
2015 Cougar 339BHS 5er
2016 RAM 2500 Crew Cab, 4x4, Laramie, 6.7L Cummins
Andersen Ultimate Aluminum 5th Wheel Connection
GONE:
2014 RAM 2500 Crew Cab, 4x4, Tradesman, 6.4L Hemi
Bionic_Man
Congrats on the milestone!
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
