We have two slides in our 2013 Coleman and the one kitchen slide just makes a horrible noise when you are letting it out or putting it in. Any suggestions? It is Lippert brand slide!!
Ours is also under warranty, so I guess we will try the spray first and see if that helps and if not then a trip to the dealer. Thank you for replying!
I just had my slide checked for a horrible noise today. I had a cracked gear pack on one arm and will also need 3 new Wear bushings. Mine is lippert as well. Parts about $110 and an estimate of 3 hours labor. Mine is under warranty so will be getting it fixed ASAP.
