Oct-05-2016 12:37 PM
Oct-18-2016 12:01 PM
Oct-06-2016 04:35 AM
Oct-05-2016 06:22 PM
All I could afford wrote:This. They're designed to leak for a while after use. Only if it's still leaking a day later do you have an issue.
Most likely equipped with a vacuum breaker in line to prevent back flow. There is probably a small sticker with tiny print worn away stating that. Some dripping is normal upon turning off the hand held hose. Continuous leakage usually means replace the valve.
Oct-05-2016 05:37 PM
Oct-05-2016 01:29 PM
Oct-05-2016 12:42 PM
Oct-05-2016 12:39 PM
