Nov-10-2016 05:50 PM
Dec-03-2016 09:48 AM
Dec-03-2016 09:16 AM
Dec-02-2016 09:53 AM
trail-explorer wrote:covered wagon wrote:
I won't be going to LEDs and there are some possible health hazards with the type of light it is.
I've never heard of this before.
People don't generally stand at the side of my RV and stare at my marker lights for hours on end, so if any health hazard does exit, it won't effect anyone.
Dec-02-2016 07:14 AM
Dec-02-2016 06:48 AM
CAJW wrote:
I'm in the same boat. 2 rear LED clearance lights have died on me with wiring apparently not being the cause. The circuit boards just gave up and getting exact replacements has been a pain.
Dec-01-2016 07:45 PM
If it comes down the replacing the marker lights, a totally sealed design is my recommendation, not a style that has a removable lens like other vendors sell.
I've installed these on three RVs and none have ever failed:
http://www.ledtrailerlights.com/cm-1a-s68.htm
Dec-01-2016 06:00 PM
Nov-12-2016 05:10 PM
HarmsWay wrote:
I'll probably try some of those sealed lights. They are at least the same size and mounting holes. Better for keeping water out of the light but a bit worse than the Bargman for keeping water out of the camper because of the exposed screws.
Nov-12-2016 02:26 PM
Nov-12-2016 06:47 AM
Nov-11-2016 02:05 PM
Nov-11-2016 07:20 AM
HarmsWay wrote:
I don't think mine are wired in series because in some cases there are 1 or 2 of the 4 working.
The appeal of LED lighting for a vehicle was not saving power (although all those bulbs do add up) but rather longer life. They have a big advantage in terms of resistance to vibration compared to incandescent. Also because they aren't user serviceable or generate much heat it should be easier to seal them from water.
Nov-11-2016 06:25 AM
Nov-11-2016 03:27 AM
