Length of torklift supertruss with Arctic Fox 992?
jayhawk75
Greetings all, been a very long time since I've posted due to being out of the RV world for a while. Buying a 2016 Arctic Fox 992 and was hoping someone can help me with info on the length of the supertruss hitch extension to get with a 2016 Ram 3500 DRW. Thanks in advance.
Arctic Fox 992
Ram 3500 DRW
7 REPLIES 7
Proav
I too am in the market for a hitch extension. I will be pulling a 12’ utility trailer with a Teryx4 SxS. But, on occasion I will want to tow a flat bed car hauler with a 4 door Jeep on the trailer.
I’m thinking the Torklift superhitch is the minimum but would appreciate any input.
Grit_dog
Navigator
Navigator
There are a few considerations, not the least of which is not wanting to have to much extension length. Only serves to add even more weight to the back of the truck.
Depends on trailer type as mentioned also, and weight of trailer. Do you need a super truss or is a solid bar extension sufficient?
Factory hitches are already good for 2000 lbs iirc tongue weight. Reduce for extension length, but you can haul a significant load without a super truss.
Food for thought
Supercharged111
The trailer tongue length will drive the requirement in length. The extra width of the camper compared to just the truck creates issues too, so having it flush may not be enough.
2007 Lance 1131
1997 GMC K3500 crew cab supercharged dually
jayhawk75
Do you have the torklift tie downs? If so did you need to get the A7004 adapter kit? I see that it may be a requirement for the Rams with DRW's, if the campers measurement is 90" or less from the front to the rear tie down point.
Arctic Fox 992
Ram 3500 DRW
noteven
Really try to have the end of your receiver flush with the very end final last end of the tow vehicle... including camper bumper step, jacks, ladders, whatever ... ask how I know this ...
jayhawk75
Appreciate the feedback!
Arctic Fox 992
Ram 3500 DRW
Geo_Boy
Chris, I have a AF990 with a Fox Landing and use a 36” long Super Truss. You could probably get away with a 32” but my trailer tracks really well with the extra length.
