โJan-07-2021 06:03 PM
โJan-08-2021 10:40 AM
toddb wrote:
I went without vehicle charging for when I switched over, I only used solar. No problems until the fridge upgrade.
I use a small one now on factory wiring and would recommend it if you want vehicle charging.
โJan-08-2021 10:23 AM
ticki2 wrote:
This is probably a dumb question , forgive my ignorance . I have been reading about these new technology batteries , lithium and now Sio2 that can be discharged to 80 and 100 percent . How do they power equipment that requires 12v to operate like a furnace sail switch , at this state of DOD ?
โJan-08-2021 10:20 AM
โJan-08-2021 10:19 AM
pianotuna wrote:
Hi,
Try SiO2 100 amp-hours for about 50% of the cost.
https://azimuthsolarproducts.com/product/12v-100ah-sio2-battery/
No need for a dc to dc charger.
Azimuth Solar Products wrote:
Settings for your SiO2 battery if you are choosing custom programming on your charge controller:
Equalizing Voltage -> 14.6 or Shut off this function if available
Boost Voltage -> 14.6
Floating Charge Voltage -> 13.6
โJan-08-2021 10:15 AM
Ramblin' Ralph wrote:
I am thinking about going with a single 100 AH LifePO4 lithium.
Doing some research it appears that a DC - DC charger is needed between the truck alternator and camper battery to protect the alternator.
Also have 125w of solar.
โJan-08-2021 09:45 AM
Ramblin' Ralph wrote:Not just the size of the battery but the size and length of the wire connecting the battery. I speculate the boat had relatively fat and short wire to reduce voltage drop to the previous lead acid batteries.
Thanks for the input. My โprotect the alternatorโ question was because of the following video I saw from Victron. Evidently the lithiums can put a higher amp load on the alternator. In their lab study one of them started smoking because of insufficient cooling while charging a 300 AH lithium.
Video here
I was just checking to see if I might have the same problem with a single 100 AH. Thanks for the tip on the SiO2 batteries. I'll look into them.
Ralph
โJan-08-2021 09:37 AM
โJan-08-2021 07:42 AM
โJan-08-2021 07:30 AM
โJan-08-2021 06:23 AM
โJan-08-2021 04:49 AM
โJan-08-2021 04:24 AM
pianotuna wrote:
Hi,
No need for a dc to dc charger. No need for a special converter. No worries about going to 0 volts.
โJan-08-2021 04:20 AM
โJan-08-2021 03:52 AM
โJan-07-2021 09:17 PM
