LP Gas Detector
mattyj
Anybody know if there is a way to test these, I pulled out my refrigerator for a repair and the LP detector kept going off ,it might have been residual gas since I disconnected gas hose from back of fridge ( telling me it works) or a low battery causing it . I just want to be sure Thanks
2006 Ford F 350, 6.0 PSD 8 Foot Bed 4x4 with Torklift Tie downs ,Stable Loads ,rear Helwig Swaybar,airlifts 5000 , Method 305 HD rims . 2019 Adventurer 89 RBS, slideout, Generator
3 REPLIES 3
_1Flyboy
Amazon has them.
stickdog
I've had to replace the propane detector in our pervious 5er it was ten years old did the same last winter on our present 5yr old. Guess they don't make them like they use to.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
jimh406
Low battery will cause it. Also, they age out, so check the age of if you take it out.
