โApr-12-2014 07:16 PM
โApr-13-2014 07:23 AM
Heavy Metal Doctor wrote:
And the flush system is a permanently installed part that came with the unit. Nothing more than a hose connection on the outside that runs to a nozzle mounted inside the black tank.
โApr-13-2014 07:22 AM
NHIrish wrote:
Be careful with the way you are doing that or you may burst your tank! If your blank tank rinse is like mine, you are not supposed to use it with the gate valve closed...too much pressure or a blocked vent and you'll have a burst tank. Having said that, I will close my gate valve for a minute and then open, repeating the process while letting the rinser do its job. I would suggest you get a clear elbow attachment to go on the sewer hose connection so you can monitor what is coming out. Fill it with water and load it up with an enzyme digester....let it sit for as long as you can. Good luck!
http://www.campingworld.com/shopping/item/90-Degree-Clear-Sewer-Hose-Adapter-with-Bayonet-Lugs/22171
โApr-13-2014 07:12 AM
Working with the industrial equivalent to black tanks makes me think this flusher is not very well designed. When we want to clean out a tank, we set fan spray nozzles so they sweep the floor of the tank towards the drain. You can have dried / caked material laying in there and it's gone in seconds.....but I don't want to tear apart my new TT and re-invent the system......
Headed back out to drain again.
โApr-13-2014 07:06 AM
Well....I actually have done all the right things, or at least tried to, in terms of leaving a few gallons in the tank, flushing the toilet with lots of water, not draining 'till at least 2/3's full and not leaving the valve open when hooked up at a site. Of course, what I learned yesterday makes me think I will not drain 'til the indicator reads full from now on.
I guess what screwed me up was that the first couple of trips where short and I did not want to leave it sitting without draining since we where coming into winter at that time as I was concerned about freezing.
I do have the dreaded "pyramid" - that's what started this whole ordeal.
โApr-13-2014 06:28 AM
Old-Biscuit wrote:
That's a new trailer.....2014 model
So I take it you have done some No-Nos
Either have left the back tank dump valve OPEN when using trailer
Have dumped black tank after each use with very little water in it
Have not added a couple gallons back into black tank after dumping so bottom stays wet
Are not using a full toilet bowl (+) when flushing solids
You have the dreaded 'poop pyramid'
Your tank flusher is just a sprayer in top of tank to help rinse down the sidewalls and rinse out tank.
It will NOT power flush the tank
You will need to power flush with a stream nozzle on end of garden hose down thru toilet to blast the pyramid. Have dump valve open
The RV Digest product does work.....but takes a while.
โApr-13-2014 05:40 AM
โApr-13-2014 03:23 AM
โApr-12-2014 11:56 PM
โApr-12-2014 10:28 PM
โApr-12-2014 09:47 PM
โApr-12-2014 07:55 PM
โApr-12-2014 07:32 PM
โApr-12-2014 07:29 PM
โApr-12-2014 07:26 PM
Porsche or Country Coach!
